Dash Squeak!
Old Mar 6, 2009 | 11:38 PM
french77's Avatar
french77
Default Dash Squeak!
My 05 MN6 Coupe with 30,000 miles is noise free except for one consistent squeek coming from the dash area. I've isolated down to either the passenger side glove box area or behind the center dash area. The squeak is there anytime the car is in motion. No different under acceleration than at constant speed. It is more noticeable on rough roads. This tells me it is probably something rubbing behind there somewhere. Anybody had this experience? I've searched many threads and have yet to see this type of squeak. (many other rattles and squeaks but not this one) Just wondering before I go disassembling the entire dash.
Old Mar 6, 2009 | 11:50 PM
Revving High's Avatar
Revving High
i tracked down a bad dash squeak. it was the plastic instrument cluster cover rubbing the bezel. I put black double sides tape in between. Its perfect. I have a weird sound from the driver window seal. sould like rubbing when its cold out.
Old Mar 6, 2009 | 11:58 PM
stoessjc's Avatar
stoessjc
I had a buzz coming from the upper right corner of the instrument cluster on my 08. I took it in under warranty and they fixed the buzzing, but the dash and A pillar trim didn't line up. I have taken back three times and they haven't been able to get the alignment right. Finally gave up with dealer. Not sure which is worse, the buzz or the misalignment. Oh well...
John
Old Mar 7, 2009 | 12:16 AM
BlueFish81's Avatar
BlueFish81
I have the same issue and have taken eveything apart to find it but nothing. That squick is driving me crazy. If you find the cause please pm me. I have not been able to find anything.
Thank you.
Karn
Old Mar 7, 2009 | 09:32 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
I hate that
Old Mar 7, 2009 | 09:34 AM
RussellZ's Avatar
RussellZ
I had the same problem with my old Lexus. I brought it to the dealership a few times and they never found the problem. I finally fixed the problem by selling it and buying my Corvette.
Old Mar 7, 2009 | 10:11 AM
Blu Mi C5's Avatar
Blu Mi C5
Default Fixed my squeeky dash
I had a squeek in the center of my dash on my 07 Z06. I was able to get rid of it by taking out the center channel speaker grill out and stuffing in some thick (1&1/2 inch) foam gasket material to the left and right side of that cavity. I did this over a year ago and the squeek is still gone.
BTW, I found that running the heat on the speaker grill for a while made it much easier to get out and it likely helps keep the speaker grill compliant. (Helps prevent a brittle fracture)
Hope this helps.
Old Mar 7, 2009 | 10:48 AM
french77's Avatar
french77
Thanks for the responses so far. I will start with some of your suggestions. I'll let everyone know when I figure it out!
Old May 18, 2010 | 01:48 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Bringing this back to the top after over a year! French, did you find the source? I developed a squeak behind the dash after installing a new clutch. I've been driving around with the center surround off for a few days now but can't find the source.
Old May 18, 2010 | 02:58 PM
mattnelson819's Avatar
mattnelson819
John
John - did it still buzz? I couldn't really care about the mis-alignment, but the buzz is driving me nuts!
Old May 19, 2010 | 03:01 AM
2006c6keller's Avatar
2006c6keller
Default Idea!
Take a plastic credit card and slide it under the plastic windshield moldiing on the inside of the car and slide it around the edge under the molding against the windshield, if it binds at all, there is a squeak there.
Old Sep 6, 2011 | 10:07 PM
c6_rob's Avatar
c6_rob
Any luck with this one?
Im having the same problem. Sounds like the dash but squeaks can be deceptive.
Old May 29, 2018 | 11:44 AM
derekrob904's Avatar
derekrob904
1st Gear
Did you ever figure out what it was?? Mine is doing the same thing and it's driving me crazy!!
Old May 29, 2018 | 12:08 PM
HBsurfer's Avatar
HBsurfer
The guy who started this thread has not posted here since 2009 so you may not get an answer
Old Jul 25, 2018 | 02:19 PM
cyberGS10's Avatar
cyberGS10
After i just replaced the trans/clutch in my '10 GS, I have some mysterious dash area squeak as well that i cannot locate...
Old Jul 27, 2018 | 01:21 AM
RadfordVette's Avatar
RadfordVette
My 08 has the "buzz" above the instrument panel, and a buzzy sound coming from radio cluster.
To Dash Squeak!
