Battery tender mounting ?
Old Mar 7, 2009 | 10:06 AM
Jeff78's Avatar
Jeff78
Default Battery tender mounting ?
I will be bringing our new car home next week. I already have a battery tender for it. Question is, where and how do you mount it? Where do you run the wires to connect to the incoming power cord?
Jeff
Old Mar 7, 2009 | 10:26 AM
yell01's Avatar
yell01
CI 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
I just hook it up to the battery and drop the cord out the bottom of the engine bay and leave it sitting on the floor.
Old Mar 7, 2009 | 10:33 AM
cthusker's Avatar
cthusker
Many options based on the the type and model of tender you purchase. I have my tender mounted onboard under the hood. The type that I purchased (Schumacher) mounts and stays with the car. I also have a CTEK US 800 for my other car but really prefer the Schumacher. I like that the battery tender is always with the car just in case I need it. Because a battery is expensive and big hassle when it fails I wouldn't skimp when buying a battery tender....
Old Mar 7, 2009 | 10:34 AM
not08crmanymore's Avatar
not08crmanymore
I just plug it in,lay the fender guard thing down and hook up the tender to the terminals.Hood stays partially opened,no big deal.Easy on and off.
Old Mar 7, 2009 | 12:51 PM
CO Lightfoot's Avatar
CO Lightfoot
That's what I do. Just make sure the clamps are secured to the terminals. I had one slip off once. The battery tender lights alerted me, so I caught it, no problem.
Great idea to use a battery tender. It's REALLY nice to have a strong battery after winter storage.
Oh, and remember to loosely stuff some rags in the tailpipes to keep bugs & varmints from nesting.
Old Mar 7, 2009 | 01:02 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Mar 7, 2009 | 01:43 PM
Ratchet Thunderbolt's Avatar
Ratchet Thunderbolt
Old Mar 7, 2009 | 01:45 PM
Ratchet Thunderbolt
Don't you just start it up and cook em?
Old Mar 7, 2009 | 01:56 PM
Hogvette's Avatar
Hogvette
Default Buy the cigarette lighter adapter
I have the CTEK unit and use the cig lighter adapter. You simply plug the adapter into the console power plug and leave the window cracked slightly to allow the cord through the window. You never have to pop the hood or crawl under the car to make the connection. I use a cover on the car so leaving the window cracked slightly doesn't bother me. This makes hooking up and disconnecting the tender very easy!
Old Mar 9, 2009 | 06:44 PM
jlvink66's Avatar
jlvink66
I was going to do the cigarette lighter connection but decided that I'd rather exit via the hood vs. the rear hatch or door/window. The connection that I show below has been described before on this forum but I thought it would be useful to add a photo.
The battery Tender Junior is supplied with a wire harness that has a two-prong plug on one end and bolt terminals on the other end. If you lift the lid to the fusebox on the right side of the engine bay you will see the positive terminal. Use a 13mm socket to remove the nut and install the red terminal from the harness. There is a good ground lug underneath the hood shock absorber. Remove the bolt with a 10mm socket and install the black terminal from the harness. Tie wrap the harness to the freon line so that it doesn't flop around. You're done! No splicing or extra parts needed!
When closing the hood I found that the cord got pinched the least by running it out by the windshield near the wipers.
John
Old Mar 9, 2009 | 08:02 PM
dvilin's Avatar
dvilin
Same here.
Old Mar 9, 2009 | 08:04 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
My Schumacher was modified and I plug it in the lighter, run the cord out a small gap in the window. Works great.
Old Mar 11, 2009 | 02:20 AM
Shawn S's Avatar
Shawn S
Same here.....
This is how my car sleeps away the bad winter weather.
It's connected directly to the terminals via the supplied lugs (which stay connected all the time) and then the extension plugs in and runs out the bottom of the engine compartment.
Old Mar 11, 2009 | 03:02 AM
CO Lightfoot
Originally Posted by Shawn S
You folded your mirrors!
Of course I've seen it done on lots of vehicles, especially pickups. Just never made the connection to do it with my Vette. My garage feels half-a-foot wider now. Nice!
Any problems leaving it that way for months?
Old Mar 11, 2009 | 04:58 AM
CO Lightfoot
Not without BBQ sauce.
Old Mar 11, 2009 | 08:47 AM
hdwideglide's Avatar
hdwideglide
Here is some info for you that helped me. See post #23. This is exactly how I did mine and it is great.
http://forums.corvetteforum.com/c6-c...k-connect.html
Old Mar 11, 2009 | 10:19 AM
PO10TIAL's Avatar
PO10TIAL
To Battery tender mounting ?
Old Mar 12, 2009 | 12:05 AM
cmonkey713's Avatar
cmonkey713
Looks exactly like my set-up.
Old Mar 12, 2009 | 02:25 AM
HuskerBullet's Avatar
HuskerBullet
cthusker, I like the idea of it staying with the car, thanks.
Old Jan 20, 2022 | 11:55 AM
madsonp's Avatar
madsonp
John
I hooked mine up the same as this, except I extended to wiring to the front grill and zip tied it to the grill so I can connect/disconnect it without having to open anything, works great
