front end rattle when going over bumps
I have an 06 corvette. it now has 19k, since 8k miles the car has had a rattle that seems to be coming from the front end. Every time i go over bumps it rattles like if something was loose. if i apply the brakes while going over bumps the noise disappears. I have taken the car in to the dealership 4 times, but every time i get it back they cant seem to ever hear the noise i described. Has anyone had or heard of this problem before.
thanks
thanks
St. Jude Donor '09, '14
Bushings on the sway bars worn out possibly? Doesn't seem like that could happen at that low miles.. but if the car sits for extended periods of time..
Do you remember hitting any pot holes? Maybe a suspension part is damaged like a front strut? There are also several parts under the hood that bolt on, maybe something's loose under there?
brake pads rattling possibly, if you can get the front in the air even if its just one side at a time and smack the tires on the middle of the thread pattern with a big *** hammer. That is usually a good way to find rattles, i would think a shock where it mounts or sway bar bushing and the brakes pads g would be a good place to start. good luck,paul
Reach up underneath and give your front sway bar a yank and see if the bushings make a clankity-clank noise.
Also check the rear because a noise in the front could mean a noise in the back with cars.. the noises play tricks on ya. Hitting the tires with a mallet would be a good idea too, like the other guy suggested.
The brake pads are fine, no issues there. I would guess the issue is tied in with the brakes becuse when i apply the brakes over bumps the rattle stops.
Thank you all for your opinions, i will try to lift the car today and check to see if i can find somthing loose (Sway bar, shocks, bracke calipers, etc
thanks
thanks
Received 2,490 Likes
St. Jude Donor '15
"In honor of jpee"
Received 2,062 Likes
The links are under tension when braking, therefore no noise then.
Was there a TSB on this? I have a similar issue, when going slow over uneven surfaces, like speed bumps, I get a clunk type noise from the front of the car, like something is loose. I had the rear end serviced recently, so I don't think that is it. Time for a trip to the dealer.
