Automatic Rear Hatch Close Down
Old Mar 10, 2009 | 01:18 AM
Don Rhoads's Avatar
Don Rhoads
Default Automatic Rear Hatch Close Down
According to the 2007 Corvette Owner Instructional DVD the C6 has a automatic rear hatch closedown & Lock Option for final 1/2 inch of downward stow position .
The DVD also said this option was deleted for Z06 for weight .
Can this option be reinstalled on a Z06 Because I really hate having to put so much force on my hatch paint & glass and also having to crack open a driver door to help relieve the vehicle from being so air tight .
Old Mar 10, 2009 | 01:21 AM
ufso's Avatar
ufso
You should post this in the Z06 section!
Old Mar 10, 2009 | 06:47 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Yes, the option can be added back in to a Z06. In fact, for 2009 the Z06 gets the option from the factory. I'm not sure on what the cost is for the new latch mechanism but you can do it.
Old Mar 10, 2009 | 07:17 AM
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
It really does not work that great.
Old Mar 10, 2009 | 07:19 AM
herbie1057's Avatar
herbie1057
I have no issues with mine. '05 For the Win!
Old Mar 10, 2009 | 07:28 AM
EuroRod's Avatar
EuroRod
My 2005 has worked with zero issues.
Old Mar 10, 2009 | 07:55 AM
bksnoopy's Avatar
bksnoopy
The auto hatch works great but at times it does fail with the doors closed and windows up. I still have to crack a window or door for it to work. I got used to keeping a door or wind open while closing the deck.
Ben, OH
Old Mar 10, 2009 | 07:56 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Wonder if the wiring is left there and the latch is all you have to install? I would think so.
Old Mar 10, 2009 | 08:00 AM
bksnoopy's Avatar
bksnoopy
It could be the 08 has a tighter seal. It would be interesting to see how many with 08's have hatch closing problems. I need an open window or door for the hatch to work right.
Ben, OH
Old Mar 10, 2009 | 10:18 AM
BEZ06's Avatar
BEZ06
I did it on my Z06, and it's a great mod!!
I had an '05 coupe and when I got the Z06 the hatch pull down feature was one of the things I missed the most - the other was the lumbar support and power seat for my wife (I did that mod too, but that's another thread!).
Mine is a daily driver and when I take my wife out shopping she's always giving me something to take out to the car and then meet her in the next store. I had to open the hatch, throw her stuff in, then either slam the hatch down, lean on it, or open a door and then close it again when I went off to find my wife. Now I open the hatch, throw the stuff in, and close the hatch and let the pull down do its thing.
It cost me about $300. In my view the only way to do it is to buy the latch from a car being salvaged and to make sure you get a pigtail of wires that you can splice into.
Here's a link to the thread where I've got a bunch of pictures and info on the install (you have to drill down to about post# 30 before you get to the install stuff):
http://forums.corvetteforum.com/c6-z...ear-hatch.html
If anybody does this and has any questions not answered in the thread just give me a shout!
Bob
Old Mar 10, 2009 | 11:56 AM
Ghost 23's Avatar
Ghost 23
Ben, OH
2008 Coupe - No issues with hatch closing.
Old Mar 10, 2009 | 11:59 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Ben, OH
Never had that problem on my '07. Works regardless of window or door state on mine
Old Mar 10, 2009 | 01:11 PM
07MontRedcp's Avatar
07MontRedcp
Works perfectly for me. It just depends on how hard you pull down.
BJK
Old Mar 10, 2009 | 01:45 PM
BEZ06's Avatar
BEZ06
Ben, OH
If your auto pull down feature isn't working then something needs an adjustment. Even with the doors closed and windows up you should just have to drop it down from about 10 inches and the latch should grab and pull the hatch down.
You can take out or add shims (what GM calls "striker spacers"):
If you can't get the hatch adjusted with the shims, you can adjust either the latch (where it bolts to the "latch mounting bracket"), or the latch mounting bracket where it bolts to the rear of the hatch compartment.
Bob
Old Mar 10, 2009 | 01:55 PM
07MontRedcp
Bob
Now that's some good info. Thanks
BJK
Old Mar 10, 2009 | 02:25 PM
lexaudio's Avatar
lexaudio
No problems here on my 06.
Works every time. I open and close the rear 4-8 times a day.
LEX
Old Mar 10, 2009 | 02:40 PM
bksnoopy's Avatar
bksnoopy
Bob
Thanks for the great information. It has not been a problem cracking a door but I will look at your instructions. I don't like to slam any of my doors, hood, or hatch. I worked with show cars in the past and you may be surprised how many door paint pops show up when people slam their doors.
I always said, when we get serious on this forum, there's loads of good information and help.
Ben, OH
To Automatic Rear Hatch Close Down
Old Mar 10, 2009 | 04:11 PM
68/70Vette's Avatar
68/70Vette
............. Even with the doors closed and windows up you should just have to drop it down from about 10 inches and the latch should grab and pull the hatch down.
I didn't think it was a good idea to drop the hatch. I gently pull mine down till it's about 1/2 inch from closing...at this distance the auto pull down still doesn't engage. Then I push down and let the motor close the hatch. My fear is that dropping (or slamming) the hatch will ultimatly damage the motor pull down mechanism. I learned to do this with my Cadillac Seville. I used to slam it's trunk lid, but after replacing two motor pull down mechanisms (they have a retail price of $400), I've learned to gently close the door on the Seville. I did a search on a Seville forum and found a lot of posts claiming that slamming or dropping the trunk lid would ultimately damage the motor. I decided to exercise the same caution with the Corvette.
Old Mar 10, 2009 | 05:43 PM
GQMGT's Avatar
GQMGT
I didn't have a problem with the hatch on my 07 until later last year. If I pushed down on the hatch to close, the alarm would go off! If I opened a window or left a door open, no problem.
Old Mar 10, 2009 | 08:19 PM
hot4u's Avatar
hot4u
Works fine on my 08
