torco octane booster
Old Mar 10, 2009 | 05:32 PM
comes alive's Avatar
comes alive
Default torco octane booster
Hi all I would like to know where I can purchase this product. I prefer forum vendors. thanks
Old Mar 10, 2009 | 05:44 PM
GCD1962's Avatar
GCD1962
Why do you want to waste your money on an octane boost additive? Your car is programed to run on pump gas.
Old Mar 10, 2009 | 05:50 PM
comes alive
Default torco
Just because of fuel in my local area and chuck cow told me it would be best to run in my car.
Old Mar 11, 2009 | 08:44 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Here you go!
Here you go!
Chuck CoW
Old Mar 11, 2009 | 09:59 AM
KENZ51's Avatar
KENZ51
I put additive in mine, I buy the 87 octane and add my own additive, that way I know its higher octane! Many times I bought 93 and it ran like 87.......
Old Mar 11, 2009 | 10:22 AM
FloydSummerOf68's Avatar
FloydSummerOf68
What additive are you using to increase 6 octane points?
Old Mar 11, 2009 | 10:38 AM
haljensen's Avatar
haljensen
Forum member jbsblownC5 can answer most of your questions about Torco, PM him.
Old Mar 11, 2009 | 10:47 AM
haljensen's Avatar
haljensen
Torco works! My personal experience with an SRT4 with the "Stage 2 w/toys" Dodge factory upgrade required 100 octane for the increased boost and timing of the "toys" function. The best way to get 100 Octane reliably was with one 32 oz can of Torco for every 10 gallons of gas.
Old Mar 11, 2009 | 10:55 AM
KENZ51's Avatar
KENZ51
didnt say it raised it 6, just saying it raises it enough that I can tell.....
Old Mar 11, 2009 | 10:57 AM
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
$20 for a quart x 4 quarts in a gallon = $80 a gallon for this crap. I don't want to hear you complaining about high gas prices if you buy this.
Old Mar 11, 2009 | 11:08 AM
CMY SIX's Avatar
CMY SIX
Why not just go and buy racing gas? you can find it almost anywhere, hell you can have it delivered by the drum.
Old Mar 11, 2009 | 11:11 AM
sox3's Avatar
sox3
You could use Toulene from you local paint store. sold in gallons very cheap, high octane. But too much will burn valves. Thats what sunoco uses in race fuel to boost octane.
Old Mar 11, 2009 | 11:16 AM
haljensen's Avatar
haljensen
Fuzzy math?
A quart of Torco treats 10 gallons to 100 octane. 10 gallons of gas = $21.00 + Torco @ $20.00 = $41.00 for 10 gallons of 100 Octane.
$4.10 a gallon is cheaper than any 100 Octane unleaded I've found.
Old Mar 11, 2009 | 11:28 AM
FloydSummerOf68
Why wouldnt you run 93 octane and then put it in to be sure you're getting the most octane you can?
If you are running lower your timing will adjust to the lower timing table.
Originally Posted by haljensen
Fuzzy math?
Agreed. Cheapest I've run 104 octane was 6.00 a gallon (havent found 100 octane...only 104 unleaded at the track when I was racing my nitrous-fed firebird)
Old Mar 11, 2009 | 12:06 PM
NYC6's Avatar
NYC6
What performance work was done to the car to require octane booster?
Old Mar 11, 2009 | 01:28 PM
C2C6Z06's Avatar
C2C6Z06
St. Jude Donor '08-'09-'11-'12
In Kalifornia, 91 is what is available. Some with Methanol (not sure how bad that really is) but the summer heat makes a difference in fuel requirement. So, IMHO, a little boost is helpful in keeping the car running its best.
Old Mar 11, 2009 | 01:50 PM
07silvervette17's Avatar
07silvervette17
From: premium smd led lights with lifetime warranty bc
yes toulene would work but how would you know how much to put in? And would the stuff at paint store be pure?
To torco octane booster
Old Mar 11, 2009 | 01:58 PM
NYC6's Avatar
NYC6
Yeah OK, but the question was directed to the OP who resides in Fla.
Old Mar 11, 2009 | 02:44 PM
reality1's Avatar
reality1
Racing gas is hard to find in unleaded in many areas and at tracks. Also,
racing fuel in an above ground tank deteriorates quickly.
Torco is a concentrate, not like the junk sold at Auto Parts stores.
I used this in my Lightning for several years and used it at the track(race program) and where I could not find 93 Octane.
Old Mar 11, 2009 | 02:58 PM
DarthStimpy's Avatar
DarthStimpy
A concentrate? as in they remove the water?
Get real. If you do the math, this stuff would need to have an Octane rating of 385 in order to achieve the claimed mixed ratios.
