Traction Control Question
I'm gonna tell you right now, not even God is going to prevent the ***-end from kicking out if you mash the throttle, let alone traction control.
The TC tries to stop wheel spin by pulling power.
The AH comes into play when the yaw-rate sensors and accelerometers detect the tail end is turning at a rate faster than the steering angle inputs and probably some other sensors in the car are calling for - i.e., the car is trying to swap ends on you. When that happens, the AH puts on individual brakes to try and stop the azz end from passing the front end.
You say the road was wet. However, with the stock tires are high performance SUMMER tires. Even if the road were perfectly dry, when the temps are down in the low 60's or especially into the 50's or below - LOOK OUT!! The tires just don't grip well on cold pavement.
Bob
Also what was the surface of the road like. Usually they are crowned. In the end, it was the steering wheel actuator's fault. In some older high performance cars you would have been spinning out in a heart beat. The car gave you a clue that you were losing it and you did the right thing in the end.
I bet it was good skill that saved you.
I'd rather try to educate you about the systems of the car than throw crap your way.
There are some forum members that don't want any help from the "nannies". They say every time they get in the car they turn TC and AH completely off.
I run on the track in either Comp or AH off completely off.
However, I never turn everything off on the street (occasionally I'll put it in Comp mode, but not very often). The race track is a fairly sterile environment, but you never know what kind of junk you'll find on the street.
I'm not good enough to beat the capabilities of the AH. It's evaluating the situation something like every 1000th of a second - and reacting that fast too. I used to fly airliners, and I wish I could fly an approach as good as a digital autoflight system can. When the autopilot flies, the needles never move. When the pilot is flying, they've got to see some movement before they can react, so the best they can do is keep the bracketing to a real low level.
On the track you don't want the AH grabbing the brakes all the time just because you're maneuvering harder than it's programmed for. Butt....on the street it's definitely your friend!
Bob
Fact is these cars are dangerous.
the AH is crap compared to the HP and summer tires which fail miserably in cool weather.
If you get a chance to Autox your car... do it.
It will give you a rude awakening as you do a spin out of control with all the nannies on.
