question about temp
Old Mar 18, 2009 | 09:12 PM
h2oskiman's Avatar
h2oskiman
Default question about temp
Has anyone tried putting a 170 or 160 degree thermosat in a stock Ls3
will the temp change effect any of the systems.Any info would be appreciated thank you
Old Mar 18, 2009 | 09:40 PM
HANNY's Avatar
HANNY
i just did last month, as far as "effecting systems" you might need to be a bit more specific what you might be worried about.
Old Mar 18, 2009 | 09:56 PM
Capt Steve's Avatar
Capt Steve
Putting a 160F thermostat would not make any difference without changing the ECM to turn the fans on sooner. Once the temp hits 160 and the thermostat opens the temp will continue to rise until the ECM turns the fans on at around 212F. So the only difference I see is that it will take a little longer for the car to reach operating temp. It is the fans that keeps the temp down. Once the stat opens, there is nothing else it effects. So if the stock thermostat opens at 198F and the fans don't turn on till over 212, having the thermostat open sooner makes no difference.
Old Mar 18, 2009 | 09:57 PM
h2oskiman's Avatar
h2oskiman
Default temp
I have had some older cars that would not shift properly because the engine didn't reach operating temp for the computor to allow things to work because of low temp didn't know if this would cause any issue's with the dic or not
Old Mar 18, 2009 | 11:20 PM
glacierbay2's Avatar
glacierbay2
Please educate us ignorants. Well...me. Why would you want to? Are you looking to reduce engine wear or up performance somehow?
Old Mar 18, 2009 | 11:36 PM
BrooklynC6's Avatar
BrooklynC6
aka allbottle¬hrottle
From: Brooklyn New York The DVL and the chicken sleep with the fishes....
St. Jude Donor '08
Exactly .
On the other hand , with a proper fan tune , yes it makes the car run substantially cooler .
And thats a good thing .
Old Mar 19, 2009 | 12:08 AM
cclive's Avatar
cclive
However, in cooler weather and at highway speed, the fan (there's only one) doesn't usually come on. In this case, the thermostat provides a minimum temp for the coolant.
Old Mar 19, 2009 | 12:16 AM
phileaglesfan's Avatar
phileaglesfan
Also in cooler weather, you want the car to warm up as soon as possible.
To question about temp
