Could VIN be wrong
Old Mar 22, 2009 | 11:15 AM
wilsogr's Avatar
wilsogr
3rd Gear
Default Could VIN be wrong
Curious about the VIN on my 2009 convertible. From what I can find the 6th and 7th character for a convertible with 6-speed manual is 36. Mine is 35. Why would that be? Thanks.
Old Mar 22, 2009 | 11:26 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
In the Corvette VIN sequence the only digit that identifies body style is the 6th digit. The 7th digit is identified as a restraint code. For the 6th digit, Body style: "1" = FRC, "2" = Coupe, "3" = Convertible. In your case having a 3 indicates that it is a convertible. The "6" in place of the "5" for the 7th digit does not talk to the body style. Here is an example of a complete 2006 VIN.
1 G 1 Y Y 2 6 U 3 6 5 1 0 0 0 0 1
There are 17 characters. Starting with first character on left the codes are:
1. "1"= Built in US
2. "G"= General Motors
3. "1"= Chevrolet
4. Denotes the car line: Corvette is a "Y" body.
5. Provides more info about the car:
Usually a "Y" but the ZR-1 is "Z"
6. Body style: "1" = FRC, "2" = Coupe, "3" = Convertible
7. Restraint code
8. Engine:
L98="8"
LT1="P"
ZR1="J"
LT4="5"
LS1="G"
LS6="S”
LS2=”U”
LS3=”W”
LS7=”E”
9. Check Digit – 0 to 9 or X
10. Model year:
"B" thru "N" are yrs '81-'92 respectively
"P"='93
"R" thru "T" '94-'96
"V"='97
"W"='98
"X"='99
"Y"='00
"1"='01
“5”=’05
“6”=’06
“7”=’07
11. Plant: Bowling Green = "5"
12-17. Production sequence number that starts with the #100001 for each model yr.
Old Mar 22, 2009 | 11:45 AM
wilsogr's Avatar
wilsogr
3rd Gear
Thanks for the clarification. I was somewhat confused after reading an article in "Corvette Enthusiast" titled "The inside scoop on 2009 corvette VINs". Then I just got the 2009 set of service manuals and the VIN system explanation in volume 1 seemed incorrect. Again, thanks.
Old Mar 22, 2009 | 11:47 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Sounds like its correct too me. The number is applied during the fabrication process and is determined when the order is placed into the system to build. What's cool is the VIN is on the engine too and is placed there during on the assembly line right above the oil filter location on the block!
Old Mar 22, 2009 | 12:03 PM
Curtis A. Franz's Avatar
Curtis A. Franz
Now if we could just get the secrets of 1953 -1980 model years. I have two owner cards from Chevrolet for my first two cars ...a 1960 & and a 1968. I do know that the engine number on the older cars was unrelated to the VIN number. I put a 327 into that 1960.
Okay here is a web site for older cars: http://www.corvette-web-central.com/...INdecoder.html
Old Mar 22, 2009 | 01:39 PM
ironmikezero's Avatar
ironmikezero
The 7th digit "restraint code" in C6s indicates airbags; "5" is standard front air bags (driver & passenger), whereas "6" is (optional) side air bags (driver & passenger).
It's also a quick way to differentiate between 1LT/1LZ models and 2LT/2LZ (and up) models, since side air bags are not available on the 1LT/1LZ models.
Old Mar 22, 2009 | 02:09 PM
Rowboat66's Avatar
Rowboat66
Originally Posted by talon90
In the Corvette VIN sequence the only digit that identifies body style is the 6th digit . . .
A very good post, Talon90. Thanks.
Old Mar 22, 2009 | 02:36 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Apr 4, 2009 | 05:02 PM
jaki30's Avatar
jaki30
Default Talon90
Sent a PM.
Old Apr 4, 2009 | 07:23 PM
RanGer498's Avatar
RanGer498
1. "1"= Built in US
3. "1"= Chevrolet
7. Restraint code
8. Engine:
L98="8"
LT1="P"
ZR1="J"
LT4="5"
LS1="G"
LS6="S”
LS2=”U”
LS3=”W”
LS7=”E”
10. Model year:
"P"='93
"V"='97
"W"='98
"X"='99
"Y"='00
"1"='01
“5”=’05
“6”=’06
“7”=’07
thanks
To Could VIN be wrong
