Cut off switch
Old Mar 24, 2009 | 08:16 PM
2001 quicksilver's Avatar
2001 quicksilver
Default Cut off switch
I am thinking of putting a hidden cut off switch in my 09 C6. In the past I have used the clutch pedal for the cut off. Does any one have any other suggestions on how to wire a cut off switch? I am also wondering if I should bother putting this in if I have the on star automatic shut down. Your thoughts?
Old Mar 24, 2009 | 08:35 PM
dpigguy's Avatar
dpigguy
not sure I see the need to do this unless you plan to leave the fob in the car at sometime. with the electronics now, your Vette isn't going to start for anyone without the fob so a cut off switch would only be needed when your fob has been stolen as well. if I did put one on the car, the clutch sounds like a good curcuit to use and should be simple to wire in, etc.
Old Mar 24, 2009 | 08:40 PM
LMB-C6's Avatar
LMB-C6
I bet there are not very many C6 vettes stolen by starting them. I think they will take what they want (like the wheels), or even just take the whole car w/o starting it. Not sure a secret switch will help unless they have the FOB.
Old Mar 24, 2009 | 08:57 PM
Mad*Max's Avatar
Mad*Max
From what I understand nobody has had their C6 stolen by starting it so you probably don't need to bother.
Old Mar 24, 2009 | 09:01 PM
spin-doktor's Avatar
spin-doktor
never heard about a C6 getting stolen without an FOB.
A cutoff switch wired to the clutch pedal sensor would be a good additional security measure if any thief ever got a hold of your FOB somehow.
Old Mar 24, 2009 | 10:58 PM
cranky's Avatar
cranky
if your concerned about theft, why not take out the fuel pump or pcm relay in the underhood fuse box when parking the car? no start then.
Old Mar 25, 2009 | 02:08 AM
RnLi's Avatar
RnLi
Actually you might have an idea here.
Why not provide a switch to the wire from the positive fuel pump feed. Someone once said if the pump doesn't have energy, the computer will not allow the starter to engage.
Maybe one of the technical guru's can answer this !!!
Old Mar 25, 2009 | 02:16 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I'd be reluctant to mess with the system. My BIL is a long time auto tech, and says that the modern computers are very sensitive to changes in resistance of the circuits.
When I installed a CB radio in my C5, suddenly I had to hold the key to "start" for about 3 seconds before the engine would crank; but only if the CB was turned off! Others reported a similar situation. Apparently the computer had to think about the tiny drain of the CB when it was off, but didn't care about the larger drain of it being turned on.
Never turn your back on an electron!
Old Mar 25, 2009 | 02:22 PM
bimmerborn's Avatar
bimmerborn
I would put in a "tilt sensor" and connect it to the alarm system instead of a cut off switch.
Old Mar 25, 2009 | 02:36 PM
Payton 63' and 06''s Avatar
Payton 63' and 06'
From: Surgeon General never said anything about smokin' tires! Pigeon Forge, Tn.
I can see this being more of an issue, for say your brother in law that you don't like, picking up your fob and messing with the car, or to keep a teenage son from taking the car while you are gone. But just straight out starting the car without the fob, like others mentioned, would be hard to do. I have done this on some older trucks that we used around the shop, that we always just left the keys in, but you had to know where to flip the switch to start.
To Cut off switch
