Detailing Stuff ?
Old Mar 27, 2009 | 11:25 PM
Cherokee Nation's Avatar
Cherokee Nation
Default Detailing Stuff ?
OK Guys---I had a BLACK 07 & now i have a BLACK 08.I have been using Wolfgang paint protection & Pinnacle carnuaba wax & detail spray from West Coast corvettes,I'm ready to change & i have seen so many threads about ZanioI checked the Zanio store,but not sure on what to buy.I have a Flex buffer,need to get the swirl marks out..........Help me out..........Thank you Much.
Old Mar 28, 2009 | 02:32 AM
NormWild's Avatar
NormWild
Zaino is typically your final step of filling and sealing. You will need other products to prepare your paint initially with the various degrees of foam pads. Clay first, then depending on the condition of your finish will dictate what to use. For Black you would most likely at least want to start out with Mazerna or 3M Swirl cutter.
As far as the Zaino, get yourself some AIO, or I use Z5 Pro with the ZFX. Get a bottle of Z6 (standard detailer) and Z8 (use after washing or in between coats of Z5).
Old Mar 28, 2009 | 03:38 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
I guess Zaino is good for Black Wolfdog loves it I used it with less success and now use NXT 2.0 on my Vred coupe.
To Detailing Stuff ?
