Dumb question...
Old Mar 29, 2009 | 12:29 AM
SC Vette06's Avatar
SC Vette06
Default Dumb question...
how do i know if i have the F55 or Z51 suspension? im the second owner so i didnt buy it new. The F55 has the suspension control in the middle of the console right? i don't have that so i'm guessing Z51?
Old Mar 29, 2009 | 12:30 AM
03 Z-oh-6's Avatar
03 Z-oh-6
Are your rotors cross drilled? If so, you have the z51.
Old Mar 29, 2009 | 12:58 AM
Vette_DD's Avatar
Vette_DD
The RPO codes for all the options are listed on a white sticker on the inside left edge of the glove compartment door. There will be a "Z51" on that sticker if your car has the Z51 option.
Old Mar 29, 2009 | 01:00 AM
moolys's Avatar
moolys
St. Jude Donor '09
Old Mar 29, 2009 | 06:12 AM
CHARMR's Avatar
CHARMR
Default Stop it; I can't stand it...
Z51's have a badge that says Z51 so that everyone will know it is a Z51. A Z51 is Z45 better than a Z06 cause it's a higher number; hince, this is why all the Z51 owners put that badge on them.
BTW: I have a Z51 without a badge so I guess mine really aint a Z51 but just a .. mmmmm .. Z.
Old Mar 29, 2009 | 08:37 AM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
WOW I need to run out and buy a Z71 truck then that should smoke yours and a Z06
Old Mar 29, 2009 | 08:39 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Mar 29, 2009 | 08:45 AM
Wass's Avatar
Wass
St. Jude Donor '09-'11
The F55 has a dial on the console with tour/sport options. You don't have that, so you either have Z51 or standard suspension.
Old Mar 29, 2009 | 08:53 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
...A Z51 is Z45 better than a Z06 cause it's a higher number; hince, this is why all the Z51 owners put that badge on them....
So I guess that puts the ZR-1 at the bottom of the list.
Old Mar 29, 2009 | 08:57 AM
Hogvette's Avatar
Hogvette
I have cross drilled rotors and the F55 option...
Old Mar 29, 2009 | 11:25 AM
JERGENSEN LS3's Avatar
JERGENSEN LS3
From: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
You may not have either.....may be base suspension.
Old Mar 29, 2009 | 11:34 AM
VettedCandidate's Avatar
VettedCandidate
Actually, the Z55 (F55 w/Z51 sways) is the best cause it is the highest number!
Old Mar 29, 2009 | 11:37 AM
mpuzach's Avatar
mpuzach
The OP had already ruled out F55 as he doesn't have the control switch on his center console.
Old Mar 29, 2009 | 12:59 PM
2006c6keller's Avatar
2006c6keller
Default I have a Z55!
I have a '06 C6 A6 F55 that has been outfitted with Z51 sway bars and Z06 brake ducts. Gosh, that ought to make me better than a Z51 because now I'm a baby ZR1!
Old Mar 29, 2009 | 01:22 PM
Vette Suspension's Avatar
Vette Suspension
Old Mar 29, 2009 | 01:30 PM
JayMack's Avatar
JayMack
CI 8-9-10 Veteran
St. Jude Donor '07-'08-'09
NCM Lifetime Member
Me, too.
Old Mar 29, 2009 | 01:32 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Not true. F55's have crossed drilled rotors too, at least on my year ('07)
To Dumb question...
Old Mar 29, 2009 | 01:37 PM
phileaglesfan's Avatar
phileaglesfan
And this is one of the most incorrect statements posted on this forum since F55 has the exact same brakes as the Z51.
The best way is to look for the Z51 code in the glove box. If you are mechanically inclined there will also be some additional coolers in the engine bay.
Drive down a somewhat bad road? Is it rough, then you have Z51. Otherwise you have base if there isn't a select **** on the console for F55.
The only way someone can tell a Z51 car from the outside is because the sway bars are thicker but this is also a simple upgrade for the F55. That is unless the Z51 owner is so proud of his option, he put a badge on the fender stating it is a Z51. Ah, but it is a performance option so I guess I should put a NPP badge on mine.
magredcpe05's Avatar
magredcpe05
switch on the consol ..period
Old Mar 29, 2009 | 02:08 PM
Vette Suspension
Don't forget the base suspension. This guy may have the base suspension. My guess is the base outsells both options.
