Build Date
Old Mar 29, 2009 | 11:06 PM
Radioactivette's Avatar
Radioactivette
Default Build Date
OK I've done a search and looked thru all the FAQ's and can't find it. Can anyone post the website that you can goto to find the build date for a 2005 C6?
Old Mar 29, 2009 | 11:44 PM
Vette_DD's Avatar
Vette_DD
No, there's nowhere you can look it up. However, if you post the VIN, someone with access to the GM VIS can look it up for you.
BigJoe's Avatar
BigJoe
Never heard of a website that would tell you that. But any dealer can run your VIN through their computer and get it for you, plus a lot of other info.
Old Mar 29, 2009 | 11:51 PM
My07C6's Avatar
My07C6
Your drivers door sticker will tell you the month/year just not the day.
Old Mar 29, 2009 | 11:53 PM
heisnuts's Avatar
heisnuts
If you look on the drivers door VIN sticker, there will be a month and date listed in the corner. In your case, it will say something like 07/05 for July, 2005. Like the others have said, if you want an exact date, you will need to have the VIN run through GM's VIS system. You might also be able to get the info from the GM Customer service 800 number. I don't know if they have the info in front of them, but it's worth a try.
Old Mar 30, 2009 | 08:15 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
check with the Dealer they can do it.
To Build Date
