Electrical Seats
Old Apr 3, 2009 | 02:07 PM
akvettelova's Avatar
akvettelova
7th Gear
Default Electrical Seats
I have an 05 c6 vette with about 31k miles and my seat will not go back! It can go up/down/forward but not back. Anyone have a solution?
Old Apr 3, 2009 | 02:38 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Where's the closest Dealer
Old Apr 3, 2009 | 06:29 PM
luvlake's Avatar
luvlake
That is why I bought a 2lt Vert. KISS
Old Apr 3, 2009 | 06:42 PM
VettedCandidate's Avatar
VettedCandidate
Look behind the seat...I have crushed things (cans) with that seat! Make sure nothing is back there. Then check the fuses, then call the dealer cause the motor is probably toast!
Old Apr 3, 2009 | 07:37 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As noted, check the seat tracks and under the seat for anything that could cause an obstruction to the seat movement. Have you checked for any codes? If it is a sensor, module or communication problem it will likely have set a code. After that it could be the switch, the track, the motor, the harness or any combination of the above.
To Electrical Seats
