How much oil ?
Old Apr 3, 2009 | 10:03 PM
Cherokee Nation's Avatar
Cherokee Nation
Default How much oil ?
[SIZE="2"]I have a 08-Z51-3LT.OK: I have only put 5.5 quarts in when i get my oil changed,well i read on threads that it takes 6 quarts & that is what the manual says.I had it changed this wk.& i had 6 quarts put in,well i checked it today & it is above the hash marks,maybe .5 of a quart.???????????/SIZE]
Old Apr 3, 2009 | 10:10 PM
not08crmanymore's Avatar
not08crmanymore
6 quarts for a STICK SHIFT Z51 CAR.Not sure about the auto version.
Old Apr 3, 2009 | 10:12 PM
Paratrooper307's Avatar
Paratrooper307
6SP Z51 here. 6 quarts is just about perfect for me, including filling the filter.
Old Apr 3, 2009 | 10:14 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
Until it's at the top hash mark on the stick. If you're .5 qt over, I wouldn't worry about it.
My non-Z51 auto LS2 is supposed to take 5.5qt and it takes 6qt to get it to the hash mark, so go figure. Maybe you're car is averaging out mine.
These threads have come up before and it's clear that cars can vary .5qt from specs. I don't think it's been determined whether it's variation in the dipsticks or something else. I did go from the stock dipstick to one of Pipedreams and mine stayed the same.
Old Apr 3, 2009 | 10:16 PM
pit-pony's Avatar
pit-pony
It's OK to be a bit above the mark.
For track use it's recomended to be 1 qt extra in the crank case anyway.
Old Apr 3, 2009 | 10:23 PM
cclive's Avatar
cclive
It takes enough to fill to the right place on the dipstick...so just put that much in.
Old Apr 3, 2009 | 10:28 PM
VET4LES's Avatar
VET4LES
Z51 gets 6 qts, standard is 5.5 qts. Transmission has nothing to do with it. Mine is always above the hash mark after an oil change.
Old Apr 3, 2009 | 10:29 PM
jpee's Avatar
jpee
I think you guys "worry" TOO much about how much oil you have... I only put in 5 qts.... and I drag race it almost every week.. i take it to 6500 rpm...
I agree if you are "ROAD RACING" and hard into cornering yes maybe you should use 6+ qts... but for street driving (even FAST) street driving 5.5 is MORE than enough..
I know MANY drag racers who have "purpose" built race cars (drag) that have run with only 3 qts of oil... But you have to remember they are only running it 1/4 mile w/ no turns for 9 -10 sec... with the oil pick up in the rear of the oil pan...
so the engine is never starved for oil.. I had a 96 LT1 (bought it new) drag raced it almost every week during race season.. and changed the oil every 3000 miles I'd use 4 qts... the car had 70,000 miles when I sold it.. ran like a raped ape.. & never had any engine problems...
I say if your NOT road racing 5.5 qts is more than enough... as for me (speaking for myself) I only use 5 qts in my C6 Z51 (A4)
Old Apr 3, 2009 | 10:39 PM
hawkgfr's Avatar
hawkgfr
Your DIPSTICK is too short....
Old Apr 3, 2009 | 10:44 PM
jpee's Avatar
jpee
You mean too LONG if its showing over full if it were too short he would show not enough oil... LOL
Old Apr 3, 2009 | 10:55 PM
Cherokee Nation
Default oil
Thanks Guys,it could be that my car was not level. ?
Old Apr 3, 2009 | 11:00 PM
hawkgfr's Avatar
hawkgfr
that is not what SHE says...
Old Apr 3, 2009 | 11:01 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Why do you purposely under fill? Is it the wt of a qt of oil ?
Old Apr 3, 2009 | 11:05 PM
johnodrake's Avatar
johnodrake
Moderator
I am under the impression that the reason that the Z51 takes .5qt more is that it has an oil cooler that the standard C6 does not have. You may not be getting all of the oil out.
Old Apr 3, 2009 | 11:15 PM
jpee's Avatar
jpee
When you race, and you have a full oil pan your crank shaft is splashing "THROUGH" the oil... (sort of like pushing an ore from a row boat through water... now if there was NO oil in the way of the crank shaft it would spin easier & make more HP (good for drag racers)
If you had a "Dry Sump" oil pump like the ZO6 then you could fill the oil as much as you want because the crankshaft wouldn't be pushing the oil aside...
I hope I'm making sense.... But we (drag racers) look at every trick in the book to make more HP... on a drag car its fine to run low oil but if your going to run road course's then you NEED all the oil to prevent it from being pulled to one side on hard cornering.. and starving the oil pick up...
In Drags you are only going straight, and if the oil pick up is at the REAR of the oil pan you won't have a problem...
Old Apr 4, 2009 | 01:09 AM
haljensen's Avatar
haljensen
Owners Manual says 5.5 quarts, I'll trust the Owners Manual.
The oil pan is a precision machined casting. I'll trust GM saying 5.5 quarts measured capacity before I trust the markings on a 2 piece dip stick that goes into a 2 piece tube with all 4 parts made by the lowest bidder.
If you want to be **** about it; Drain the car overnight, fill the filter with oil from your 5.5 quart purchase, install the filter then add the balance of the 5.5 quarts thru the oil fill cap. Start the car, run it till it reaches operating temp then shut it off. Let it sit overnight again, pull the dipstick, wipe it clean, re-insert the dipstick, pull it out again and mark the oil level by scoring the dipstick with the edge of a file. Now you have a 5.5 quart full mark that is accurate.
Old Apr 4, 2009 | 01:28 AM
cclive's Avatar
cclive
Amazing...
To How much oil ?
Old Apr 4, 2009 | 07:07 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Transmission DOES have something to do with it because the extra pint is for the LS2 Z51 oil cooler but the auto doesn't have that cooler whether or not it has the Z51 package..
The correct answer, already given several times, is it takes as much as it takes but better to be a little over than under. Not WAY over but a little over.
Old Apr 4, 2009 | 09:12 AM
HPVA's Avatar
HPVA
I also have a non Z51 auto its a 2006 convertible and it takes 6 qts. to bring it to the full mark on the dipstick.
Old Apr 4, 2009 | 10:05 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
