You can buy the brake kit which comes with the larger drilled rotors and caliper mounts.
As far as the rest , you can get the sway bars and shocks or aftermarket eqivilent. Trans and rear end gearing is also possible but really not practical if you just drive normal street. There are also trans and oil coolers which again can be added. I might of missed something but someone will chime in!!!!
