Help with driver's side window problem
Old Apr 4, 2009 | 10:00 PM
3blondesandMe's Avatar
3blondesandMe
Default Help with driver's side window problem
I took the cover off my '05 a couple weeks ago to check that my battery was ready to go and it was fine. This morning I took the cover off to drive it for the first time this year and the battery was completely dead. Wasn't sure why, but I charged it slow all day and it was fully charged tonight.
So I took it out for a little ride to make sure I had not left any Acc on last time which might have caused the battery drain. Long story short; I discovered that my driver's side window does not go up the last 1/2" to seal itself shut.
Does anyone know what is wrong and what I should do next?
I have tried up, down, power on, off; opening and closing the door etc and it just won't go up.
Any help would be greatly appreciated.
Old Apr 4, 2009 | 10:04 PM
mikez51c6's Avatar
mikez51c6
St. Jude Donor '11
Old Apr 4, 2009 | 10:06 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
you need to re-index the windows after dead battery or if the battery is disconnected.
Details are in the manual, you will be told
Basically , sit in the car, close both doors , turn ignition on , roll both windows together all the way up , keep holding the up both buttons for 10 seconds, release , then hold up again for another 10 seconds , that should clear your problem .
Old Apr 4, 2009 | 10:07 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Your windows may need to be re-indexed by doing the following:
RicK T's Avatar
RicK T
Re-index......when you close the windows, hold the switches up for 3 seconds after they reach the top. Let go of the switches then hold them up again for 3 seconds.
Old Apr 4, 2009 | 10:10 PM
Vette_DD's Avatar
Vette_DD
Windows always need to be re-indexed after disconnecting, then re-connecting the car battery. Usually, that's all.
Be sure to remember to do both of them.
Old Apr 5, 2009 | 12:31 AM
3blondesandMe
Thanks for all the quick feedback. Problem solved. I feel like a complete moron though since I looked right at the section in the manual and never read it to make the connection myself.
Nice to have a place to come for help.
Old Apr 5, 2009 | 01:43 AM
inthehunt2's Avatar
inthehunt2
Worked for me. All else fails, read the manual!
To Help with driver's side window problem
