Strange electrical problem
Old Apr 5, 2009 | 10:25 AM
SteveJ's Avatar
SteveJ
Default Strange electrical problem
Wife called me from work Friday at about 1:00. She had driven our 08 about 4 miles to work at about 8:30 and couldn't get out of the car without using the mechanical emergency release. She wanted to trade cars because she didn't trust the Vette. I went to her office and the car was undrivable because the battery was almost completely run down. I had to get in the car using the emergency mechanical hatch release. The car was flat bedded to the dealer, and they called Friday night to say that the car seemed fine after charging the battery. They are going to keep the car through Monday since their Vette specialist will be in to look at it. The car started up fine Friday morning and everything seemed normal. It had been sitting for about a week. Any ideas?
Old Apr 5, 2009 | 10:47 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Other than the car sitting for a week how often does it get driven and how far? For example, if your wife drives the car to work 4 miles each way every day your battery would likely be dead in about a month. 4 miles is not going to be enough to even replace the amount of charge it took to open the doors and start the car.
You might consider a battery tender if the car is just a weekend cruise or short trip car. The Corvette C6 battery charge will last unattended for about 27 days on average. It can take up to 30 minutes to replenish the battery just from opening the door and starting the car.
Old Apr 5, 2009 | 10:48 AM
RicK T's Avatar
RicK T
How long had it been sitting before she drove it Friday AM?
Old Apr 5, 2009 | 10:50 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
Your best course of action will be to wait until Monday and see what Vette Tech finds out. If you need additional help after that, then ask away.
Fill us in on the diagnosis too.
Old Apr 5, 2009 | 10:56 AM
SteveJ's Avatar
SteveJ
The car had been sitting for a week after a 20 mile drive which should have fully charged the battery. It had not been driven since then until Friday. I'll keep everyone updated.
Old Apr 5, 2009 | 11:06 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Please do
Old Apr 6, 2009 | 06:57 PM
SteveJ's Avatar
SteveJ
Here is the promised update. Basically, they could find nothing wrong. They did replace the top latches according to the service bulletin. I'll keep an eye on things to see if it can be reproduced. I have a battery charger in the garage, so no big deal if it happens again at home. In the meantime, walking away and leaving the car for a couple of hours if the door doesn't open properly is not an option. I'm wondering what happens if the button on the door is working properly and the solenoid that opens the door sticks? Is the car smart enough to know that the door didn't actuate, or does it keep sending current to the solenoid?
Old Apr 6, 2009 | 07:13 PM
RnLi's Avatar
RnLi
Steve.....
If the car sat for a week or so, was driven for 20 miles, and then sat for a week again....the 20 mile drive is not sufficient to recharge a battery, even it's it's just slightly low. Especially if the radio, heater fan, lights were also used either, or both, of the 2 times it was driven.
Just noticed you are in Minnesota. I'll bet the spouse used some power robbing accessories in her 4 mile drive....while the battery was low.
Put the charger on it and if it's an auto regulating, wait till it indicates zero or turns off. Check the voltage with a meter. Then check again in several days....see what difference you have, if any (make sure all accessories are off...including courtesy lights).
Just some guesses on my part.
Old Apr 6, 2009 | 07:49 PM
danl72's Avatar
danl72
Originally Posted by Red Rochester
[/B]
Please do
SteveJ's Avatar
SteveJ
I should have added some new information on the failure to the update. I found out a couple of days ago that after my wife used the emergency release to open the driver's side door, she walked around the car and opened the passenger door normally to get some stuff out of that side of the car. Therefore, we know that there was significant discharge with the car just sitting there after she went in to work.
Old Apr 6, 2009 | 08:00 PM
08 Crystal Red's Avatar
08 Crystal Red
Just recently had a similar battery problem my self. Car had set for about a month - after a long hard drive. The battery had just enough charge to let me get in but not enough to recognize the presence of the FOB or start the car. I put a charger on the battery and only got it to a 50% charge which quickly faded to zero. I guessed that 3 cells were bad.
Took the battery to the nearest dealer and they confirmed the dead cells (BTW, dealer offered to come and put the car on a flatbed free of charge to get it too the dealership but I said "No thanks"). Battery was replaced under warranty and all is now well.
Old Apr 6, 2009 | 08:01 PM
inthehunt2's Avatar
inthehunt2
I started this thread a week ago or so. Some interesting reading. Please see...
http://forums.corvetteforum.com/c6-c...-the-deal.html
Old Apr 6, 2009 | 10:03 PM
HANNY's Avatar
HANNY
a load test on the battery and Alternator should give you the answers you need, short of a freaky alt. or very unusual electrical issue.
A battery tender would be a good idea if it sets a week (which disharges the battery) and then is driven short periods alot (which doesnt charge the battery enuf) but thats asking alot to get the wife to plug one in. good luck , paul
Old Apr 6, 2009 | 10:29 PM
dpigguy's Avatar
dpigguy
have your dealer or another shop if you don't trust your regular mechanic, to load test the battery and alternator as suggested. believe it or not, a 20 mile trip is not enough to charge the battery on a C6. you need over 30 minutes about 1500 rpm to gain on replacement of the power you used just getting started. need to drive the car more or get a battery tender to keep the charge up while its in the garage.
Old Apr 6, 2009 | 10:36 PM
phileaglesfan's Avatar
phileaglesfan
That sounds strange since it didn't allow her to use the interior driver's door open button but then allowed her to use the exterior pax handle. Unfortunately as cars have new power features they depend on the battery more and more, something that really hasn't been updated as quick in my opinion.
To Strange electrical problem
