Valve Stem Caps...
Old Apr 7, 2009 | 05:16 PM
KarKrazy's Avatar
KarKrazy
Default Valve Stem Caps...
I know this sounds like a dumb question, but here goes... I've been told that if you use chrome valve stem caps they the wheel sensors will cause them to seize and you can't remove them. Has anyone else ever heard of this? Had a new set of ZR1 wheels installed and that is what the tire shop stated today.
Old Apr 7, 2009 | 05:21 PM
TEXHAWK0's Avatar
TEXHAWK0
Yes, you have dis-similar metals and you can get galvanic corrosion set up.
I would refrain from using the fancy caps and use the plastic or aluminum caps that come on a lot of other GM cars.
Our Impala came with lightweight aluminum caps and they look fine.
They look like A305 in this picture.
http://www.acmeautomotive.com/upload.../Page%2013.pdf
Old Apr 7, 2009 | 05:28 PM
ufaj26's Avatar
ufaj26
This is new to me ! ! Learn something every day I guess.
Old Apr 7, 2009 | 05:29 PM
C8-Vette's Avatar
C8-Vette
I've had them on my 05 for over 4 years without a problem. I check my air pressure at least monthly and they remove easily.
Old Apr 7, 2009 | 05:30 PM
speedster516's Avatar
speedster516
I was told the same thing by my mechanic.
jackcasa's Avatar
jackcasa
However. . . you can use the chrome plated plastic caps with the C6 emblem on the heads. I've used these on my C5 and transferred them to my C6 with no problems, ever.
FWIW. . .
Old Apr 7, 2009 | 05:44 PM
cranky's Avatar
cranky
FWIW. . .
have had them on my 05 for four years, no problems at all
Old Apr 7, 2009 | 05:56 PM
hawkgfr's Avatar
hawkgfr
we seems to have a difference of opinion.....
Old Apr 7, 2009 | 06:04 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
The valve stems are the antenna for the LTPWS and changing the cap may have an affect on their ability to communicate wirelessly. I just read that in Vette magazine 10 minutes ago.
Old Apr 7, 2009 | 06:06 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
I'm keeping mine a die hard decesion
Old Apr 7, 2009 | 06:20 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You need to concern yourself with two things when you swap your valve stem caps. You need to avoid material that could cause interference with the transmission of the signal from the TPMS. As was indicated above, the second thing that you need to concern yourself with is the possibility of corrosion (galvanic) that can be cause by two dissimilar metals in contact with each other. If you find caps that are nickel plated or plastic caps that are chrome covered you should be fine. However, the metal caps that are chrome plated can in fact cause trouble with the sensor readings.
There is a note in the service manual about this:
''the cap is aluminum and the valve is nickel plated to prevent corrosion and are not to be substituted with a cap or valve made of any other material". Page 3-93, 4th paragraph.
Old Apr 7, 2009 | 06:43 PM
calemasters's Avatar
calemasters
xTooltipElement
Service Information 2005 Chevrolet Corvette | Corvette (VIN Y) Service Manual | Document ID: 2260127
#08-03-10-005A: Use of Chrome or Chrome Plated Steel Valve Caps on Aluminum Valve Stems - (Mar 31, 2009)
Subject: Use of Chrome or Chrome Plated Steel Valve Caps on Aluminum Valve Stems
Models: 2010 and Prior GM Passenger Cars and Light Duty Trucks (including Saturn)
2010 and Prior HUMMER H2, H3
2009 and Prior Saab 9-7X
This bulletin is being revised to include the 2010 model year. Please discard Corporate Bulletin Number 08-03-10-005 (Section 03 -- Suspension).
This bulletin is being issued to inform dealers about the use of chrome or chrome-plated steel valve caps on aluminum valve systems.
Dealers/customers cannot install a chrome or chrome-plated steel valve cap on an aluminum valve system. If this happens, the contact between the different metals results in galvanic corrosion, which will seize the cap to the stem and may fracture the stem when attempting to remove the cap.
Inform customers of corrosion issues when chrome or chrome-plated steel valve caps are used on aluminum valve stems.
Use only plastic or aluminum caps with aluminum valve systems.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2009 General Motors Corporation. All rights reserved.
Old Apr 7, 2009 | 10:33 PM
akriggm's Avatar
akriggm
Any thoughts on using chrome plated brass caps? Any materials engineers out there??
Enjoy,
akriggm
Old Apr 7, 2009 | 10:45 PM
inthehunt2's Avatar
inthehunt2
I'm not a materials engineer, however I thought this might be an option. Made of the same material as the OEMs, but with a different face on the top. I think they are a stylist mod to the wheels and no interference with the TPMS.
Old Apr 8, 2009 | 08:04 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Enjoy,
akriggm
The greatest galvanic problem is between aluminum and brass. Chrome plated brass could be an issue if the chrome on the threads wears through, or the threads were not fully plated to begin with.
Old Apr 8, 2009 | 08:14 AM
vettenut's Avatar
vettenut
KY Events Coordinator
Default V S Ca[s
I use chrome caps with the C6 logo on them without any problems.
Old Apr 8, 2009 | 08:28 AM
KarKrazy's Avatar
KarKrazy
Thanks for all the information... I knew this was the right place for the correct info!
To Valve Stem Caps...
