I have a couple slight scratches on my front bumper. I bought the car used and it had them on there perhaps someone backed up on it. It really isnt that bad you can only notice it when your up on the car. I have tried waxing and using clay bar and doesnt seem to be working any suggestions.
Try Meguiar's Fine-Cut #2, followed by Meguiar's #7 Mirror Glaze or 3M Imperial Hand Glaze and then wax. Works for me on light scratches. If they don't disappear, they will become less noticeable. You'll get 50 different answers but try this way first as it's fairly gentle.
Sounds like it will at least need high speed buffing. I think it would be worth it to go to a pro detailer or body shop. Find one with an experienced professional buffer who knows what he is doing. Likely only a few dollars to take care of it. Good luck.
I've used the same Meguiar's products with good results!
All the previous suggestions definitely have possibilities, but if you can catch the scratches with your fingernail it's most likely past the point of polishing/buffing. They may improve somewhat, and that could be good enough rather than opt for repainting a complete fascia. Good luck!
first off i want to let you guys know yall are incredible with the responses matter of minutes so thanks a lot. I went from not knowing what to do to having options to choose from. So again thanks.
