Mild2Wild Zero drain or regular method?
Old Apr 9, 2009 | 10:40 PM
kev1n's Avatar
kev1n
Sounds like draining the battery would take a couple of things to take place to avoid it I guess you need to hit the "off" button before shutting the car off? Other wise if you leave it in "ON" ( normal closed flap mode) and don't drive for 3-4 weeks then you can potentially drain the battery ?
Are those correct assumptions? IN theory it seems that it could be "Zero Drain" with the traditional install as long as you open the flaps before shutting down.
Old Apr 9, 2009 | 10:42 PM
Ames's Avatar
Ames
If you do the zero drain does it remember the last setting, go to wild mode, or mild mode? It almost sounds like people are saying it defaults to wild? I'm going to install my this weekend...
Old Apr 9, 2009 | 10:49 PM
kev1n's Avatar
kev1n
This is what I think
Zero Drain = Wild Mode at Startup
Normal = Last setting remembered at Startup
Normal can drain battery if:
1. you leave it in the "ON" position
2. shutdown for 3-4 weeks at a time in the "ON" position.
Old Apr 9, 2009 | 10:51 PM
starr1's Avatar
starr1
I first used the regular hook up and experienced a sluggish battery on future starts. I then used the zero hook up and have not had any battery issues. I use the battery tender during the winter months when the vette is put up, but so far as a weekend driver everything seems to be O.K. Good luck.
Old Apr 9, 2009 | 10:52 PM
SonOfDreams's Avatar
0SonOfDreams
Former Vendor
St. Jude Donor '09
Honestly this thread is becoming full of miss information, I have posted the answer and the instruction have 5 pages of facts. If anyone has additional questions please send me an email or PM
This is correct
Zero Drain = Wild Mode at Startup, can be switched to Mild prior to starting the car if needed, if you press the ingition button without stepping on the clutch or brake.
As delivered = Last setting remembered at startup and can be switched prior to starting the car. Minimal drain if left in the "ON" (OEM shut at startup) setting and could impact startup after 3-4weeks or no use or if not on a battery tender. Almost no drain if left in the "OFF" (Loud always open) setting, really no impact for months.
Old Apr 9, 2009 | 11:27 PM
bub's Avatar
bub
Originally Posted by TEXHAWK0
If you are worried about battery drain during the winter when the car is not driven for several months, you can always just unplug the MTW connector.
If doing so, one should be sure to unplug the piggyback fuse, and not the white powered lead. The white lead could be left energized and short itself out on a ground inside the fuse block area, potentially damaging the controller and at a minimum blowing the fuse...
Old Apr 10, 2009 | 11:10 AM
spinkick's Avatar
spinkick
This is correct
How do you have it installed on your vette? Which do you prefer?
Old Apr 10, 2009 | 11:24 AM
0SonOfDreams
Former Vendor
St. Jude Donor '09
From post #8
If you are asking me, we have NPP in a box so the install is unique. In the 2yrs we tested mild2wild without the zero drain install we never had a dead battery and we generly only drive 1 or 2 times a week and in the winter 2-3 weeks would go buy.
Old Apr 10, 2009 | 11:26 AM
spinkick's Avatar
spinkick
From post #8
Thanks! Can't wait for mine to get here.
Old Jan 22, 2010 | 06:04 PM
Chris3's Avatar
Chris3
1. NPP in a box installs in the seat heater fuse so you always have 0 drain.
2. Yes you can get NPP in a box with the old school foot switch (speical request)
I dont have heated seats in my car....is there still a empty fuse slot there, so that I can install the zero drain option?
Old Jan 22, 2010 | 07:30 PM
dvilin's Avatar
dvilin
I have the M2W with the regular set-up not the zero drain. I leave it in the open position and have not had any problems. It has been on my Vette for 18 months, but...during Winter storage I also use a Battery Tender.
