08 shift boot ring question.
Old Apr 11, 2009 | 11:18 AM
not08crmanymore's Avatar
not08crmanymore
Default 08 shift boot ring question.
Can that thing be moved from one shift boot to another???Thanks.
Old Apr 11, 2009 | 11:32 AM
Tom_Slick's Avatar
Tom_Slick
DSVettes has a write up on their site on removing/ adding a shift boot...
http://dsvettes.com/new/pdf/DSV_Shiftboot_install.pdf
Old Apr 11, 2009 | 11:35 AM
not08crmanymore
The link doesn't work.
Old Apr 11, 2009 | 11:38 AM
Tom_Slick's Avatar
Tom_Slick
Link updated...
Old Apr 11, 2009 | 11:52 AM
not08crmanymore
Thanks.Don't think I saw the ring but I'll look again.
Old Apr 11, 2009 | 12:34 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
don't believe you can. I wanted the ring on my 05 , so I ended up ordering an 09 whole new boot from Gene. It's not come in yet ,but he told me to get the ring I had to order the boot, and I did.
I think it was $60 - $70 range.
Old Apr 11, 2009 | 12:37 PM
Tom_Slick's Avatar
Tom_Slick
My bad, I misunderstood which part you were asking about... You meant the chrome ring built into the radio bezel/ console?
Old Apr 11, 2009 | 12:44 PM
TLK's Avatar
TLK
St. Jude Donor '09-'11
It doesn't come off. It looks like it's been crimped together somehow, and the whole thing is probably too flimsy to tolerate any fiddling with.
Unfortunately, if want to keep using the ring retainer, you should probably get a boot that has one, like the GM accessories ones (they do have two tone). With DSVettes boots, you probably don't really need a ring.
Old Apr 11, 2009 | 12:48 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
I removed the trim ring from the stock boot and installed it on the DSV boot with no issues.
Old Apr 11, 2009 | 01:02 PM
not08crmanymore
Thanks anyway.
How??
Old Apr 11, 2009 | 01:45 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Turn the stock boot inside out and you will see how the ring is secured to the boot. If I recall correctly, the ring is secured by a piece of vinyl string and just cut it off. The ring comes out and install in the new boot. The ring was a tight fit in the DSV boot and did not need secure it to the boot. I have had no issues so far and stays is place.
Old Apr 11, 2009 | 01:47 PM
not08crmanymore
Thanks!
Old Apr 11, 2009 | 01:50 PM
vetehead's Avatar
vetehead
I hope you know that the shift **** is different too,the **** has a keyway slot for the chrome ring to lock into.
Ron
Old Apr 11, 2009 | 05:47 PM
car2fast4you's Avatar
car2fast4you
I have the DS Vettes shifter boot on my 08.
The chrome ring has a deep groove in it that top of the OEM boot slips into.
You just have to pull the boot firmly to release it from the ring.
The DS Vettes boot leather is MUCH thicker than the OEM vinyl.
If you work at it, you can get the DS Vettes boot to slip onto the ring.
It's a VERY tight fit, but it will go on.
So, yes, you can use the 08 OEM trim ring with a DS Vettes (or similar) boot.
Also.....
The DS Vettes **** also has thicker leather.
Because this, it is difficult to snap the chrome ring back onto the shifter.
But IT WILL snap on......and, you can get it back off if you need to.
Old Apr 11, 2009 | 08:42 PM
corvettezman
Ron
Yep ordered that too , since I went with the entire 35% 09 Z06 shifter package and the 09 shifter boot and ****.
My 05 **** had the checkered pattern to it and I needed to get away from hat since i upgraded the console to the black CF . Lots of mods
To 08 shift boot ring question.
