Weird: Corvette Bolt Missing
Old Apr 13, 2009 | 12:47 PM
Ahmer's Avatar
Ahmer
Default Weird: Corvette Bolt Missing
I went yesterday to look for a squeak problem in my car and went to look under the car by the left rear wheel and noticed "THE ENTIRE SWAY BAR" just hanging by only the right clamp. It seems like the top bolt on the left clamp "simply fell off" and the entire clamp was bent over all the way down and the sway bar was jiggling...
I went to chevy to ask for a replacement bolt as the hole was clean (no broken bolt). They tol dme to go to a regulr hardware store as the bolt was M 12 X 1.75 X 30. Lo and behold 10 min. and $1.47 later, I'm back at my house attempting to bend the clamp back.
Finally got it on. had to rig upa set up including a socket wrench handle which I "threaded" through the clamp hole and "jacked" the clamp back up. Then used a LARGE 20 in. breaker bar to screw the bolt back on.
Finally done.
Man, was that an experience
One Note. The "stiffness" of the ride is back. I always wondered why my car "softened" down a bit.
Old Apr 13, 2009 | 12:51 PM
gbgary's Avatar
gbgary
cool.
o/t...find your tires yet?
Old Apr 13, 2009 | 12:52 PM
Vette Suspension's Avatar
Vette Suspension
Finally done.
Something like this happened to a friend of mine. Found out some teens were messing with his car. He placed a video camera in the window after the second time and recorded them in the act.
Old Apr 13, 2009 | 12:59 PM
torquetube's Avatar
torquetube
I had a similar problem. On my C6, the lower bolt on the same clamp on the same side managed to unwind itself about halfway out before I noticed it.
Old Apr 13, 2009 | 01:26 PM
68/70Vette's Avatar
68/70Vette
They tol dme to go to a regulr hardware store as the bolt was M 12 X 1.75 X 30. Lo and behold 10 min. and $1.47 later.....
Just a general information comment. Some hardware stores will sell poor quality nuts and bolts. I only use grade 8 on my cars. Grade 8 for strength and also it's hardened cad plated surface provides a little natural rust resistance.
Old Apr 13, 2009 | 02:00 PM
Vette Suspension
Great point.
Old Apr 13, 2009 | 02:04 PM
cclive's Avatar
cclive
Since most hardware stores don't have a huge selection of metric bolts, they are usually of higher quality. With english bolts, they usually have grade 2, 5 and 8....I've never seen a hardware store that carried three grades of metric..
Old Apr 13, 2009 | 03:44 PM
marathon's Avatar
marathon
St. Jude Donor '09
Here's the torque specs for the rear stabilizer bar:
Stabilizer Shaft Insulator Clamp Bolt 65 N·m 49 lb ft
Stabilizer Shaft Insulator Clamp Nut 95 N·m 70 lb ft
Stabilizer Shaft Link Nuts 72 N·m 53 lb ft
Old Apr 13, 2009 | 03:57 PM
Ames's Avatar
Ames
That's really weird. Were they trying to make him crash or something? You'd think they would stick with egging, something in the gas, or keying it.
Old Apr 13, 2009 | 04:24 PM
scottycards's Avatar
scottycards
St. Jude Donor '08 thru '13
You won't be able to find Grade 5 or Grade 8 in metric.
Metric are 8.8 and 10.9 respectively, and will be stamped on the head of the bolt.
For an SAE bolt, three hash marks on the bolt head indicate Grade 5, and six indicate Grade 8.
As for plating, shiny silver bolts are generally Zinc coated, with a clear chromate finish.
Yellow bolts are Yellow Chromate, which offer a slightly higher resistance to "white rust" (or chalky corrosion), in areas of high moisutre.
Grade 8/10.9 bolts will be rated to 150,000 psi tensile strength, and Grade 5/8.8 bolts will have a 120,000 psi tensile strength rating.
While some suspension parts require Grade 8, or 10.9 metric, unless specified, or unless you need the additional resistance to corrosion, Grade 5/8.8 will be adequate.
Having all Grade 8 is fine, but weigh the benefit vs. costs.
Note- 68/70 Vette is correct- at Home Depot, your bolts may not even meet Grade 5 standards, and may not offer any corrosion protection, so get your bolts for your car somewhere reputable, like a good parts store, and check the bolt markings to ensure that they meet the strength and corrosion standards you require.
scotty,
former nut and bolt salesman
Old Apr 13, 2009 | 05:28 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Good job dosen't that make you feel good to do it yourself. At least you know it was done right
Old Apr 14, 2009 | 07:45 PM
Ahmer's Avatar
Ahmer
Absolutely. Now I think I may be paranoid because everytime I get out of my car I check under my car to make sure the bolt is there. Hehe
OCD.
Old Apr 14, 2009 | 07:49 PM
RanGer498's Avatar
RanGer498
scotty,
Old Apr 14, 2009 | 07:55 PM
Vette Suspension
I don't know. My guess is they wanted something to hang from the bottom. Kids now are really weird. MTV has destroyed their mushy skulls.
Old Apr 14, 2009 | 08:08 PM
Hoonose's Avatar
Hoonose
OCD.
Loose sway bar bolts was or is still a common problem. At least with the '05's. Also loose axle bolts, especially the rear passenger side.
Old Apr 14, 2009 | 09:21 PM
GotVett?'s Avatar
GotVett?
What???
Old Apr 14, 2009 | 11:37 PM
Hoonose's Avatar
Hoonose
Originally Posted by GotVett?
What???
Like I said.
Both are common problems, just do a forum search and see.
To Weird: Corvette Bolt Missing
Old Apr 14, 2009 | 11:47 PM
MarkRx's Avatar
MarkRx
Old Apr 15, 2009 | 01:37 AM
Vette Suspension
Originally Posted by MarkRx
Old Apr 15, 2009 | 01:48 AM
mountain ride's Avatar
mountain ride
when I bought my 05...I was under the chassis and found the left sway bar clamp loose with the top bold approx 1/2 way out of its threads...of course I responded...going through the whole car and checking things like NUTS & BOLTS...I feel better now....
