Lug nut socket ?
Old Apr 14, 2009 | 05:47 PM
SnapperDragon's Avatar
SnapperDragon
Default Lug nut socket ?
Is there a special lug nut socket that is commonly used that does not damage the lug? I have yet to take off any of my wheels and before I do I'd like to get the right part so I don't damage the lug nuts.
Thanks.
Old Apr 14, 2009 | 05:49 PM
68/70Vette's Avatar
68/70Vette
Yep. I think I bought mine from Corvette Central. The socket is nylon lined so as to not damage the chrome plating. They also sell lug nuts that require a special tool to remove at least one lug nut per wheel.
The replacement cost of a set of stock wheels and tires is really expensive.
Old Apr 14, 2009 | 05:50 PM
RadarP3C's Avatar
RadarP3C
I use these from Northern Tools........
Old Apr 14, 2009 | 05:52 PM
ufso's Avatar
ufso
harbor freight has them too
Old Apr 14, 2009 | 05:54 PM
johnodrake's Avatar
johnodrake
Moderator
Thanks.
These will work. http://www.mytoolstore.com/astro/asthan16.html
19mm
Old Apr 14, 2009 | 06:04 PM
SnapperDragon
Cool. Thanks a lot guys. Looks like my next purchase once I decide which one(s).
Old Apr 14, 2009 | 06:12 PM
MARSC6's Avatar
MARSC6
I just use a regular 6 point socket. I've had the wheels off many times with no damage to the lug nuts.
I was told if I didn't use an impact there would be no need for a special socket. Was also told lined sockets were to thick to fit in some wheels.
Old Apr 14, 2009 | 06:21 PM
orca1946's Avatar
orca1946
I have the plastic lined one, it sticks to the nut & comes out of the metal socket ??!!
Bob06COUPE's Avatar
Bob06COUPE
Default nothing special
I use a craftsman 19mm 6 point socket by hand and have never had any damage....using a air impact might have a different result.
Old Apr 14, 2009 | 06:34 PM
ron-z51's Avatar
ron-z51
You guys got chrome lug nuts with you stock wheels? I bought my 08 new and was disappionted on how cheap the lug nuts look, they are capped with stainless caps that are really dull. The are definately NOT chrome plated.
Old Apr 14, 2009 | 08:58 PM
cmonkey713's Avatar
cmonkey713
No need for expensive sockets, I use a deep six point with black electrical tape on the outside not to damage the wheel.
Old Apr 16, 2009 | 08:28 AM
Hansoncw's Avatar
Hansoncw
Napa Autoparts sells a 19mm plastic lined socket on the outside and plastic on the bottom of the inside and it sells for $10
Old Apr 16, 2009 | 08:30 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
A good 6 point socket shouldn't damage the lugnut.
Old Apr 16, 2009 | 08:57 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
got mine from Mid America $20
Old Apr 16, 2009 | 10:03 PM
VRedZ06's Avatar
VRedZ06
St. Jude Donor '10
Thanks.
I learned the hard way a long time ago that some of the wheel manufacturers use special lug nut sockets for their rims. They will not damage the rim or the Lug Nut. If you ever by a set of rims, ask the manufacturer if they have any special lug nut sockets for the rim you are purchasing. I had a exotic car that used a thin walled lug nut socket for the OEM BBS rims, anything else would tear up the lug nut wall holes on the rim. Well I was in a jam and used the standard socket and they wouldn't fix the rims free, (they did discount the repair) but it was my fault for not haveing the socket in the tool bag where it was when I purchased the car.
Old Apr 16, 2009 | 10:21 PM
SnapperDragon
Thanks to all.
Old Apr 16, 2009 | 11:53 PM
jackcasa's Avatar
jackcasa
I bought one from CC also in anticipation of using it to remove the lug nuts on my new ZR1 repop wheels from WCC. After I had the wheels installed and drove the car 100 miles I went to retorque the wheels and found that the socket would not fit into the recess for the lug nuts. Bummer! Checked the '05 OEM wheels and found it fit with no problem.
Anybody want to by my CC nylon lined socket?
To Lug nut socket ?
