spoiler removal
Old Apr 14, 2009 | 08:27 PM
Lambvette's Avatar
Lambvette
Default spoiler removal
How do I remove my 08' Coupe spoiler?
Old Apr 14, 2009 | 08:31 PM
RicK T's Avatar
RicK T
Here is a step by step. It's very easy just take your time. And you might want to put a couple of towels inside the fascia in case you drop a nut. Don't ask how some of us know that.
http://forums.corvetteforum.com/1561912997-post8.html
Old Apr 14, 2009 | 08:33 PM
OhNiner's Avatar
OhNiner
Remove the two inside taillights, you will need a torx wrench for them. Remove the screw from the top and rotate them down and out from the top. Then reach inside and feel for the four nuts on the spoiler bolts, mine were only hand tight. Make sure not to drop them. Before you lift up the spoiler unplug the 3rd brake light. It has a squeeze tab on the top side of it I think. Pull off the wire harness and then lift off the spoiler.
Old Apr 14, 2009 | 08:38 PM
LMB-C6's Avatar
LMB-C6
IIRC, I think I was able to get to all the nuts on my spoiler by removing just one of the inner brake lamp assemblies...or maybe I just have long arms.
Old Apr 14, 2009 | 08:43 PM
stroked250's Avatar
stroked250
I just did this about 30 minutes ago. Without ever doing this before, it only took me abour 15-20 minutes. I used the torx to take the lights off, but I was able to spin the nuts off the spoiler mount without a socket!
Old Apr 14, 2009 | 08:47 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
http://www.vettepitstop.com/faq.php
Old Apr 14, 2009 | 10:16 PM
Lambvette's Avatar
Lambvette
Thanks guys! You've made this a lot easier.
Old Apr 14, 2009 | 11:03 PM
CQRT's Avatar
CQRT
Even after you spin off the nuts, you'll want to be patient and push up with your finger on the bottom of the studs - -on mine, it was an extremely tight fit and I was trying not to break anything. I also had my patience tested getting the wiring coupler unplugged.
Beer helps . . .
Old Apr 14, 2009 | 11:27 PM
Rogers 07's Avatar
Rogers 07
[QUOTE=RicK T;1569706539]Here is a step by step. It's very easy just take your time. And you might want to put a couple of towels inside the fascia in case you drop a nut. Don't ask how some of us know that.
Trust us, USE A TOWEL !!!! Those nuts must be a lot heavier than they look !!!!!!
Old Apr 15, 2009 | 09:57 AM
alamike's Avatar
alamike
The hard part is the blind demating of the electrical connector. The remainder of the job is a piece of cake.
Old Apr 15, 2009 | 10:29 AM
BRIANSC6's Avatar
BRIANSC6
Just be careful not to drop the nuts connecting the spoiler to the car that's an awful dark void with lots of nooks and crannies for it to fall into.
Old Sep 17, 2010 | 11:10 AM
markmott's Avatar
markmott
St. Jude Donor '16
Thanks all for the good info. What looked like might be a little difficult at first turned out to be a 20 minute job.
Old Sep 17, 2010 | 11:45 AM
JoesC5's Avatar
JoesC5
I was able to pull the spoiler free of the bumper and then disconnected the electrical clip. I reconnected the electrical clip before mounting the spoiler back on the bumper. The leads are not that long but long enough.
Old Sep 17, 2010 | 12:48 PM
markmott's Avatar
markmott
St. Jude Donor '16
Install spoiler first then reconnect wires. Lots of room to get your hand in there so no problem. The clip is on the bottom.
To spoiler removal
