Service Active Handling
Old Apr 14, 2009 | 09:57 PM
JONS 07's Avatar
JONS 07
Default Service Active Handling
OK, the car has been stored for 6
months w, CETK charger, 40 psi in
tires, Stabil in fuel.
Well, start it up today to bring
the Vette into service, and...........
get 'SERVICE ACTIVE HANDLING"
display in the DIC. Push Traction
control button and it only shows
on or off, no comp mode or all off.
What happened while she was sleeping?
Old Apr 14, 2009 | 10:02 PM
RicK T's Avatar
RicK T
Here is the most complete explanation I have seen. There are a couple of DIY repairs around but you should just take it to the dealer ASAP. It has the potential to be a safety issue when driving.
http://forums.corvetteforum.com/1565795159-post2.html
Old Apr 14, 2009 | 10:12 PM
JONS 07's Avatar
JONS 07
Thanks, I read Talons post
and he knows what he is talking
about.. This is just a P...er, as I
was ready to drive the car and bring
it out of retirement. It went to bed with
no messages, and woke up 6 months
later with this one.
Anyone else have , or seen of this
HIBERNTATION problem before?
Thanks, Jon
Old Apr 14, 2009 | 10:20 PM
inthehunt2's Avatar
inthehunt2
Not that I doubt Talon at all, he's quite knowledgeable!
One other possibility though...
When I put my Vette into hibernation, I take the battery out. I do not leave it connected to the vehicle power harness, nor do I leave it physically under the hood. The point here is BO ELECTRICAL CONNECTION TO THE VEHICLE.
The reason I say this is that some maintenance charges have a high-freq pulse mode that aids in keeping the battery plates clean during non-use. One of the reasons I disconnect the battery from the vehicle is that I don't want high-freq pulses making it to any of my electronics. Yes, the battery acts like a big capacitor, and yes, all modules must pass a CI (Conducted Immunity) EMC tests as well, but I just don't like the idea of high-freq making it to any electronic modules on the vehicles. If it makes it to the modules, then you have to rely on internal filtering in each modules downstream of it's internal power regulating system. As more modules are added to the vehicle, the more the chance that one of them could be damaged due to high-freq pulsing on the power feed.
I am not saying that this is root cause, just wanted to share my thoughts.
JMHO
Old Apr 14, 2009 | 10:26 PM
C6~Missle's Avatar
C6~Missle
Not sure how you had your car stored.. But it couldn't hurt to disconnect the battery and reconnect it.. low voltage conditions can play havoc with electronics sometimes.. I was getting all kinds of false codes when my battery went south.. all was well when it was replaced
Old Apr 14, 2009 | 10:36 PM
inthehunt2's Avatar
inthehunt2
Unless the battery voltage dies in the middle of a memory write to Flash memory. If the write is not successful, then ka-boom. Most modules have software written to make sure a memory write is successful before a low battery condition (called LVI). Also, most software is written to check memory on power-up and if it's scrambled, then there are some algorithms that can sense this and then recover. Unfortunately, not all suppliers that supply OEMs have this kind of smart algorithm, thus there is a wildcard chance that something will get scrambled and will need to be reflashed...
Old Apr 14, 2009 | 11:04 PM
JONS 07's Avatar
JONS 07
It was stored with a CETK charger
and it eas always on. I did start it\in mid December,
ran it for 30 mins, wtith no DIC message.
Today, I staet it and SERVICE ACTIVE HANDILING
comes on : Mystery to me. I have not disconneted
the battery yet.
Thanks for all the replys: keep them coming,
Jon
Old Apr 15, 2009 | 01:54 PM
Jimmy 2 Times's Avatar
Jimmy 2 Times
dont put it away for the winter
i don't even put my bikes away, there are always some nice days to ride/take the vette out
To Service Active Handling
