'07 Key Question
Old Apr 20, 2009 | 05:45 PM
Mad*Max's Avatar
Mad*Max
Default '07 Key Question
I find the key quite bulky and was wondering what is underneath the black plastic if you grind it away? Can you still put it on a key ring?
Old Apr 20, 2009 | 07:44 PM
RicK T's Avatar
RicK T
I'm not sure what an '07 key looks like but I'm guessing it is similar to this:
http://forums.corvetteforum.com/1562522175-post1.html
Old Apr 20, 2009 | 08:00 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
My key had NO HOLE after you grind off the plastic. I carry the key in my wallet.
Elmer
Old Apr 20, 2009 | 08:58 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
You can buy an 08 Fob with the hide a key.
Talk to Gene Cully.
It will work in your 07 as long as the first cut is not a zero or whatever that means.
He can order you the FOB/Hide a key and tell you if you key can be cut to match.
Old Apr 20, 2009 | 09:14 PM
VETTE IV's Avatar
VETTE IV
The B106 key blank is too large to suite me so I trimmed one down a bit.
http://i650.photobucket.com/albums/u...etteiv/key.jpg
Old Apr 20, 2009 | 09:51 PM
RicK T's Avatar
RicK T
Your link doesn't work, no image there.
Old Apr 20, 2009 | 09:57 PM
Fonzijr1964's Avatar
Fonzijr1964
Talk to Gene Cully.
it's a 1 in the code and all you have to do if you have one is buy the fob and the blank key from Gene (or your parts depot) and get an 07 key cut than cut off the head and drill a whole and it will fit in the new fobs
Old Apr 20, 2009 | 10:03 PM
VETTE IV's Avatar
VETTE IV
I'll try it again:
Old Apr 20, 2009 | 10:12 PM
eboggs_jkvl
Moderator emeritus
The question was, "What is under the black plastic?" No hole is under the black plastic of the 07 key.
Elmer
Old Apr 20, 2009 | 11:15 PM
cclive's Avatar
cclive
No hole is under the black plastic on the original GM key. Aftermarket keys from companies like ILCO are made in two types. B-106 and BP-106. The B-106 is like the Saturn key pictured above...it has a hole. BP-106 has a plastic head and no hole if you grind off the plastic. I took a BP-106, which is easier to find, and cut off the plastic head, ground it down, and then drilled my own hole so I could put it on my keyring. It now basically has no head on it. It is the same width all the way from one end to the other. Takes up very little space on my ring. The ring itself acts as the handle to give leverage when turning it in the lock.
Old Apr 20, 2009 | 11:59 PM
danl72's Avatar
danl72
Talk to Gene Cully.
Old Apr 21, 2009 | 07:47 AM
Mad*Max's Avatar
Mad*Max
Thanks everyone for answering my question.
To '07 Key Question
