GCA Splash Guard Install
Old Apr 20, 2009 | 11:02 PM
cmonkey713's Avatar
cmonkey713
Default GCA Splash Guard Install
This weekend I installed a set of GCA splash guards on my buddy's '09 Black vert he got from Gene Culley.
For all that are thinking about doing this mod, let me tell you it is a piece of cake. On a scale of 1 to 10, ten being the most difficult, this is a two (2). The install took about 40 minutes. They look perfect on the car. Being black they become almost invisible unless you know that they are there. The C-6 should have come with these installed from BG.
Old Apr 20, 2009 | 11:18 PM
Monts's Avatar
Monts
Glad I did mine. Toughest part was taking off the rear tires. I spent over one hour in the rear compartment looking for the jack.
Old Apr 20, 2009 | 11:20 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Cool waiting on my set to come in
Old Apr 20, 2009 | 11:23 PM
danl72's Avatar
danl72
Cool. We need some pics.
Old Apr 20, 2009 | 11:32 PM
RadarP3C's Avatar
RadarP3C
I installed mine last week. I wish these were available when I first bought the car.
BTW....the spare and jack is in the third cubby.
Old Apr 20, 2009 | 11:58 PM
AmmoVet's Avatar
AmmoVet
Right next to the miniature spare tire.
Old Apr 21, 2009 | 07:35 AM
lander's Avatar
lander
St. Jude Donor '09-'10-'11
Just finished installing mine last night (did the fronts over the weekend, then couldn't get my jack under the car to finish the rears, so I had to buy a new jack). I like them because they are so subtle on the car (VR) and they just look "right".
I'll get some pix tonight and post.
Old Apr 21, 2009 | 08:19 AM
SvetteC6's Avatar
SvetteC6
They look good, reasonable price, and work well. It's a no brainer.
Old Apr 21, 2009 | 08:21 AM
JSB LS3's Avatar
JSB LS3
I agree....only ones available for C6 fenders that look like they were designed to be there.
Old Apr 21, 2009 | 08:43 AM
lander's Avatar
lander
I had to walk away from the computer last night after seeing some other "splash guards" advertised here...I had absolutely nothing good to say and wanted to tell the OP how ugly they were...but I refrained.
As you said...these look like they were made for the car...maybe because they were?
Old Apr 21, 2009 | 08:49 AM
jcase10's Avatar
jcase10
St. Jude Donor '10-'11
Yeah I just removed those splash guards and chucked em in the trash. Just getting some time to install the GM ones I just got from Gene. OBTW thanks Gene.
Old Apr 21, 2009 | 10:01 AM
EVRGRN's Avatar
EVRGRN
I installed mine over the weekend and am very pleased with them too. I am not the kind of guy to put badges or extra chrome do-dads on the car, so the splash guards had to look right - and they do. I didn't get them for "splash" protection, but to prevent unsightly rock chips around the wheel wells.
I installed mine when the temperature was hovering in the low 60s, which is on the low end of the recommended temperature range for installation. That might be why the tape on the rear guards did not hold well at first. I added some extra 3M double-sided tape and they're holding on well now.
I picked up the 21/64" drill bit at Sears since I couldn't find it at Home Depot.
Old Apr 21, 2009 | 11:51 AM
JetsRUs's Avatar
JetsRUs
Same here. I couldn't find the 21/64" at my local Lowes. Sears had it.
The best advice I received on the install...
Make sure the guard is exactly where you want it before pealing the tape backing off.
Old Apr 21, 2009 | 12:16 PM
Chrisbert's Avatar
Chrisbert
Is this the kit you bought?
||--Genuine GM C6 Splash Guards--||
19170234 – 2005-2009 Splash Guards – 105.00
I didn't see any drill bit called out in the install instructions for those though.
Old Apr 21, 2009 | 01:34 PM
JSB LS3's Avatar
JSB LS3
you do in fact need a 21/64" bit. It has to be exact because the holes you're drilling will be filled with barbed body pins and they have to be tight.
Old Apr 21, 2009 | 01:39 PM
Snowwolfe's Avatar
Snowwolfe
I just used a 5/16th bit and the pins went in without any problem. 5/16 calculated out to 20/64's
Old Apr 21, 2009 | 01:43 PM
ALD_Z06's Avatar
ALD_Z06
Pics of GCA Splash Guards on Black
To GCA Splash Guard Install
Old Apr 21, 2009 | 01:51 PM
EVRGRN's Avatar
EVRGRN
Looks great ALZ51
Old Apr 21, 2009 | 06:10 PM
ALD_Z06's Avatar
ALD_Z06
Looks great ALZ51
Old Apr 21, 2009 | 06:27 PM
lander's Avatar
lander
Ok, here they are on my VR:
and as you can see, nearly invisible from the 3/4 angle:
BTW, what you can't see are all my lug nuts properly torqued to 100ft/lbs
