Inquiring mind
Old Apr 22, 2009 | 06:38 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Default Inquiring mind
to know...
why just the pilot side heated seat is not working. Co-pilot side works fine. Press pilot side heat button and it flashes once and dies.. Circuit breaker works as the windshied wipers and co-pilot heat works...
07 coupe, 50350 miles
Old Apr 22, 2009 | 06:43 PM
VET4LES's Avatar
VET4LES
Originally Posted by Grumpy
to know...
Could be many things but it sounds like a bad switch to me. If there was a short in the system the fuse or circuit breaker would blow.
MARSC6's Avatar
MARSC6
I'd start by checking the switch and the connections under the seat.
Old Apr 22, 2009 | 06:46 PM
RicK T's Avatar
RicK T
Connectors under the seat have been the culprit many times. Hope that's all it is. Best of luck.
Old Apr 22, 2009 | 06:54 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
You might also want to check the "Driver's Heated Seat" fuse:
Old Apr 22, 2009 | 07:13 PM
Grumpy's Avatar
Grumpy
MONARTOR
damn... now I gotta go look... BRB
Old Apr 22, 2009 | 07:25 PM
Grumpy's Avatar
Grumpy
MONARTOR
cb is fine.. connector looks good..
Old Apr 22, 2009 | 08:32 PM
johnebgoode's Avatar
johnebgoode
If all the things mentioned above check out...ya may have to take a look at the heat coils themselves, they may have a break in them. That means removing upholstery from seat cushion.
Old Apr 22, 2009 | 08:39 PM
AtHomeSoda's Avatar
AtHomeSoda
Default Well
ah.... you can check... before removing the seat cover....
Really... check to see if the Load side is OPEN... if it is the heater is bad... if not.. look to the switch... check voltage to load side... man... this is easy stuff...
Old Apr 22, 2009 | 10:07 PM
6SPDRCR's Avatar
6SPDRCR
If all that fails. Simply don't use it.
Old Apr 23, 2009 | 10:41 AM
Grumpy's Avatar
Grumpy
MONARTOR
after wiggling and jiggling the connector, reseating the CB , damn thing works fine friggin electrons
Old Apr 23, 2009 | 10:43 AM
vetdude's Avatar
vetdude
You sure you didn't just forget to put on the BVDs?
Old Apr 23, 2009 | 10:50 AM
Grumpy's Avatar
Grumpy
MONARTOR
probably wasn't holding my tongue right
Old Apr 23, 2009 | 10:53 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Apr 23, 2009 | 10:57 AM
lander's Avatar
lander
St. Jude Donor '09-'10-'11
If you were holding it with your right hand, then yeah. What happens is when you reached across with your left hand to press the button to turn the heaters on, your right cheek depressed into the seat too far, thus breaking the heater connection.
If you'd have used your left hand to hold it, then this wouldn't have happened.
To Inquiring mind
