Update On PAL!
#122
Corvette Enthusiast
An automotive part is "released" into the system once it has passed software and hardware validation. Once it is released if the software or hardware update is to an existing part it is then processed by the assembly plant.
If not, there are additional test runs and quality checks before the part is given to dealers.
A "Release Engineer" is the person who "releases" the part, this only releases it to Manufacturing. This is not the same thing as it being commercially available.
#123
Received 1,660 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Count me in on that group purchase when the PAL comes out I like the nav, but I almost considered getting the 2LT base model instead of the 3LT Z51 I did buy because of the inability to hook up my iPod.
#124
Please add my name to the group buy list as well. I was getting ready to do the XM-splice mod, but the PAL sounds more interesting!!
Enjoy,
akriggm
#125
Like many I too am waiting on the edge of my seat for PAL to be available.
Please put my name e on any list you have for PAL.
I have an 08 C^ 3LT with Nav, for what it'd worth.
Gene, thanks for keeping us in the loop.
Bill
Bill
#126
If it will not support charging for the newer iPhone and iTouch, then it is a total waste as far as I am concerned. I have an US Spec and all I had to do was send it back to them for some quick whatever (got the exact same box back as I marked mine just to see if I did) plus different cable and it charges my iPhone3G and iPod Video. I would not even consider a change no matter how good the interface is unless it charges. Period. I guess I will wait to see while I still use the USA Spec. I also have the ProClip so my iPhone or gen 5 iPod can just slip into a cradle and charge, play, etc. AND sill have access for phone. If it HAS to be in the glove box, that will cause another problem. Oh well................such is life............Those who want a very slick, professsional car dock for the iPhone/iPod be sure to check out ProClip
http://www.proclipusa.com/site/frame...0&pageid=14216
http://www.proclipusa.com/?sectionpa...oryid=&p_year=
#127
http://www.scosche.com/products/sfID...productID/1667
The problem stems from Apple's change from Firewire protocol to USB 2.0. Any device that worked to charge first gen iPod's won't work to charge fourth gen nano devices and iPhone's and iPod Touch. Inversely, any device that will work to charge the iPhone and such devices, won't work on the earlier units.
As an aside, I completely agree with you on the Proclip units. They make some of the best holders I've ever seen and I use their stuff in my daily driver. Just aweome and very well designed and manufactured.
#128
Emerging Vendor
Even if it doesn't charge out of the box there is an inline adapter that will take care of the charging solution. The device is made by Scosche and it is called the Passport:
Hi Paul,
I believe there is even a better solution for the new Ipod/Iphones than the Scosche adapter. Since I did my review on the aftermarket Ipod adapters:
http://forums.corvetteforum.com/c6-c...-corvette.html
the aftermarket adapters had the same issue - the new Ipods/Iphones wouldn't charge. Two of the aftermarket adapters (USA Spec and Peripheral) came up with a solution that provided a new Ipod connection cable that would charge both the old and new Ipod/Iphones. But Scosche and P.I.E. did not come up with the cable solution, but rather offered the adapter you describe.
But the drawback to this adapter, in my opinion, is that, while it works, it creates a large and cumbersome connector that you plug into the Ipod/Iphone. As an alternative, Peripheral (or iSimple as it is also known) offers a new charging adapter cable that you connect onto the old cable and it extends the cable another four feet. You can then hide the cable connection and you end up with the same smaller Ipod/Iphone connector at the Ipod/Iphone itself.
This adapter cable, the iS710, does the same thing electronically as the Scosche adapter, but it is more convenient to use. Here are a couple of links to it:
http://isimplesolutions.com/CES/ReVolt.asp
http://www.discountcarstereo.com/detail.aspx?ID=1337
While I don't know any of the details of the PAL device, I would think this charging adapter should work on it just as well as the aftermarket adapters. Actually, I'd be surprised if the PAL, supposedly being the newest technology on the market, didn't already provide a charging cable for the newest Ipod/Iphones. If the aftermarket suppliers already have the solution, you'd think it would be simple for the PAL designers as well.
The older Ipods, like my Generation 3 Ipod Nano, used a 12 volt charging system, while the new ones use 5 volts. These adapters are backwards compatible with all Ipods and Iphones. I cover some of these charging issues at the end of my updated review at:
http://www.kawal.net/ipod.htm
By the way, Paul, your tutorial on using the factory Nav system is sure good:
http://forums.corvetteforum.com/c6-c...rough-5-a.html
Ray
#129
Hi Paul,
Ray
Ray
Thanks for the note. I really appreciate the thoughts on the navigation tutorial, that means a lot to me coming from you. Look for an email on this from me....
Unfortunately the timing of the PAL and the abrupt change by Apple on the charging protocol left the option to adapt the new protocol out and such, it is stuck in the old charging system and will not charge the iPhone, iPod Touch or the Gen 4 units. I'll look in to the cable solution that you provided. I can't see any reason why that wouldn't work. It's nice to have options. I agree that the Scosche is a little larger than probably desirable. I do know the Scosche solution works as I use their dock adapter with my sound dock in my office as I have a first generation dock with my iPhone 3G.
Paul
#130
Emerging Vendor
Greetings Ray,
Paul
Paul
"Revolt Mini", or iS712, which is essentially the same charging adapter as the Scosche:
http://isimplesolutions.com/CES/ReVoltMini.asp
http://www.discountcarstereo.com/detail.aspx?ID=1351
P.I.E. also has one, but Jay at Discount Car Stereo advised of some issues with it. It would be interesting to know if the same company makes all of these adapters - probably not, but they all sure look similar. I would think any of them, including the extension adapter cable (iS710) would work on the PAL.
Regarding your excellent navigation tutorial, I plan to add a post to your thread, but I haven't yet had a chance to get through all of it. You have so much good information in there, but I only found out about it just before my wife and I left on a three week road trip to Utah. We just got back and so I'm still trying to catch up. I do plan on thoroughly reading everything in your tutorial, because even though I thought I was familiar with the Nav unit, I've already learned more details from your report.
Ray
#131
Corvette Enthusiast
Ray,
Thanks for the ReVolt link, I've been looking to scoop up one of those for my iPhone when I use it instead of my iPod Classic with my PXAMG.
I too think this adapter will work fine with PAL.
#132
#133
As I said on my USA Spec, they had me change out the cable and then it would charge the iPhone3G BUT they said it would not charge it as fast as the new standard (what every that meant) but I could send the unit back & they would do something for free that would bring it up to current speed charging. I am not sure what all that means, but I can tell you for a fact that the original USA Spec unit would not charge my iPhone3g, then I got their replacement cable and it did charge. Even though I did not really understand the fast charging issue, I went ahead and set all 3 of my units back for the free update to the box. Right now I can charge, play, etc. my iPod Video,iPhone3g and my wife's Nano (original version).
#134
Premium Supporting Vendor
I have been keeping an eye on it and I will certainly stock up and help out all of the forum members I can.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
