Delco Battery
Old Apr 24, 2009 | 03:53 PM
Gman in NC's Avatar
Gman in NC
Default Delco Battery
Went to my dealer today to see about a new Delco Battery for my 2005 C6. It's $107. That's ok with me. But, he said the listing called for a 590 amh battery. That seems low to me. Is this correct? My battery is the original one, never failed, and has never been on a tender. Wondering if I need to do this right now.
Old Apr 24, 2009 | 04:09 PM
calemasters's Avatar
calemasters
AC/DELCO 86-7YR or 86-6YR is the correct battery for the 2005 Corvette. I do not remember the CCA or amp hours off hand.
Old Apr 24, 2009 | 05:21 PM
BigJoe's Avatar
BigJoe
Reading through all the battery posts here I concluded that the factory battery seems to either die immediately or after about 3 years. I replaced my 2005's battery about 6 months ago just as a preventive measure even though it was working fine. There is just too much stuff depending on it to not be careful.
I put in a new Delco at the dealer and it hasn't given me any problems since.
Old Apr 24, 2009 | 05:28 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
The big problem with batteries is how long the the car sits at the dealers before it sold.The constant deaths a battery goes through and recharging shorten the life.
Old Apr 24, 2009 | 05:59 PM
cclive's Avatar
cclive
590-610 sounds right to me...mine is a 2007 and the Delco is 600 CCA
Old Apr 24, 2009 | 06:18 PM
Bellboy's Avatar
Bellboy
I believe the AC/Delco 86-6YR battery is 590 CCA. That sounds kind of low but I guess you don't need a lot of CCA when you have the gear reduction starter.
Old Apr 24, 2009 | 06:28 PM
C6~Missle's Avatar
C6~Missle
They don't like deep discharges and will likely fail shortly after you experience one.. ask me how I know...
Old Apr 24, 2009 | 07:14 PM
calemasters
86-6YR is 590 CCA, 110 minutes reserve
86-7YR is 690 CCA, 105 minutes reserve
Old Apr 24, 2009 | 07:41 PM
rdm1465's Avatar
rdm1465
Sounds about right to me. But, if you don't have any problems yet, why change it? Unless you happen to just want to be on the safe side. My '06 hasn't given me any problems, I got it in "05. My '03 Yukon hasn't failed me yet, I got it in '02. Never seen a battery tender or needed to be jumped. It's got alittle over 21k on it.
Batteries and anything electrical, can fail from the moment you put it in. Just my opinion.
Old Apr 24, 2009 | 07:47 PM
Gman in NC's Avatar
Gman in NC
Thanks guys. I will get that battery but just might ride this one out for awhile. It's been good. My C6 was an ordered car so it didn't sit anywhere very long. Thanks again.
To Delco Battery
