Center Consel Lock Missing
Old Apr 27, 2009 | 02:13 PM
leatherneck21's Avatar
leatherneck21
Default Center Consel Lock Missing
Does any one else know why the 08 Vette does not have a lock for the center consel?
Old Apr 27, 2009 | 02:16 PM
dvilin's Avatar
dvilin
Cost?
Old Apr 27, 2009 | 02:18 PM
Shortimer's Avatar
Shortimer
My guess is GM just went a little cheap. They also got rid of the light under the hood. Those little changes add up when trying to cut costs. It's a bean counter thing not that GM felt they were improving the car by removing these features.
jc9767's Avatar
jc9767
They put the lock on the doors instead.
Old Apr 27, 2009 | 03:01 PM
NevadaVette's Avatar
NevadaVette
GM has routinely deleted standard equipment and raised prices to create inventory. The place has been run by morons.
You can install the prior version of the arm rest base with the lock kit in an 08 (make sure that you get all the lock parts - some should come with the base). However, the lock kit is a plastic cylinder kit with steel inserts and unless you are a lock person you will likely have to go to a locksmith to get it keyed. The console base is priced reasonably but the lock kit is way overpriced. However, it is only about $10 to match your ignition key if you get it keyed before you install it. When you see what it is you won't want to mess with keying it yourself. Everything else is pretty easy to change out.
Note that the later style 08 key blank is narrower than the original key blanks used on the C6. The lock cylinder kit can be made to work with your existing key but the key will feel a little wobbly when it is inserted. When you are all done, you will have a plastic lock, which can deter the casual thief looking for something open but not much else.
I wouldn't be surprised if GM actually scrapped the console lock because they didn't want to come up with a new lock kit to correctly accomodate the new size key blanks.
Old Apr 27, 2009 | 03:07 PM
leatherneck21
Good info, thanks! I leave the glove box and center consel open when I go somewhere to let people see there is nothing to take. I don't know if thats good or not, but it's almost impossible for the car to get stolen as is. I would definatly make some interior changes myself, but getting rid of the lock would not be one of them!
Old Apr 27, 2009 | 03:11 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
They would just break it getting in.
Old Apr 27, 2009 | 03:12 PM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
the console lid is so easy to pry up..so if you lock it... its asking for it...there goes a ton of console damage... if they take the time and make the effort to break in your vette...they wont let a console lock stop them.
Old Apr 27, 2009 | 03:37 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Originally Posted by NevadaVette
GM has routinely deleted standard equipment and raised prices to create inventory. The place has been run by morons.........
Maybe they are morons and car thieves.
Actually 2 good reasons to get rid of it.
Old Apr 27, 2009 | 04:13 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
It was discontinued beginning with the 07's.
Old Apr 27, 2009 | 04:14 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
cost reduction.
Old Apr 27, 2009 | 05:36 PM
RadarP3C's Avatar
RadarP3C
The 07's didn't have the console lock.
NevadaVette's explanation makes sense also since the 07's were supposed to have the new style fob with the inserted key like the 08's.
Old Apr 27, 2009 | 06:30 PM
ALD_Z06's Avatar
ALD_Z06
That's why I have my fob in the first place. If there is a console lock, I would need a key to unlock it. I like leaving a fob in my pants and not using a key of any type. I think that's what the reasoning behind it is.
Old Apr 27, 2009 | 06:39 PM
Tom_Slick's Avatar
Tom_Slick
Along with the under hood light...
Old Apr 27, 2009 | 06:40 PM
bimmerborn's Avatar
bimmerborn
Sure, key change, fob change, ...
While we are on the "feature missing" subject can you tell me where did these go ?
- Trunk pull down handle
- Orange ambient LED lighting on passenger sunvisor
- Hood light
Old Apr 27, 2009 | 06:43 PM
danl72's Avatar
danl72
GM also got rid of the orange light in the passenger sun visor to help light up the interior at night.
Old Apr 27, 2009 | 07:09 PM
johnodrake's Avatar
johnodrake
Moderator
I would surmise that it is because it was worthless! When I had my console leather covered, I didn't bother to put it back on. The lock would keep no one out.
To Center Consel Lock Missing
Old Apr 27, 2009 | 10:44 PM
Capt Steve's Avatar
Capt Steve
With the new fob style, there is no readily available key. I think it had more to do with the fob and the whole "keyless" premise. Now what happened to the underhood light and the ambiance light, who knows.
Old Apr 27, 2009 | 10:51 PM
HarleyB's Avatar
HarleyB
The General took it out (along with the light) to reduce weight for racing applications!
70454's Avatar
70454
The lock may not keep someone out, but would ruin the chances of someone who casually tries to pilfer the compartment for a radar detector, cash, etc. I use the compartment all the time on my 05 when I don't feel like putting the top up every time I park. If you're parked in a place where you've gotta worry, the top would be up anyway. I personally find the lock very useful.
By Michael S. Palmer | 2026-06-03 09:39:05
