Stupid Question
Old Apr 28, 2009 | 08:19 PM
Hypertrophy's Avatar
Hypertrophy
Default Stupid Question
I had a C5 and I recently traded for a C6. So, tonight I was driving home, and I don't know what possessed me to do this, but I was going about 30mph and I was in Neutral, so I just grab the shifter and slide it right into 4th gear, not aggressively, just a normal shift, without using the clutch and it didn't grind or anything. . .Is this normal? My C5 wouldn't even come out of gear without engaging the clutch, much less going into a gear without using the clutch. . .Just curious!
Old Apr 28, 2009 | 08:56 PM
shopdog's Avatar
shopdog
If you know how, you never need to touch the clutch, except when pulling off from a stop. It is just a matter of matching RPMs so that you're at the no load point when you disengage or engage a particular gear.
Old Apr 28, 2009 | 08:59 PM
RicK T's Avatar
RicK T
I used to do it all the time with manual trans cars.
Old Apr 28, 2009 | 09:04 PM
Walt White Coupe's Avatar
Walt White Coupe
You were lucky!
Old Apr 28, 2009 | 09:36 PM
Hypertrophy
Cool, I got a lifetime warranty, might have to experiment a little!!
Old Apr 28, 2009 | 10:01 PM
spin-doktor's Avatar
spin-doktor
you can shift without using the clutch at all if you can match RPM's. Tricky to do but ive done it a couple of times.
Old Apr 28, 2009 | 10:07 PM
Just Buy It's Avatar
Just Buy It
But it is really a thing you should NOT do. WHY?
Old Apr 28, 2009 | 10:23 PM
deputydawg40's Avatar
deputydawg40
Nothing unusual about shifting a transmission without using the clutch. Truck drivers do it all the time including downshifting, just a matter of matching the rpms. They usually only use the clutch for initially getting the rig rolling and when stopping. Can also be done with an unsychronized transmission by making a fast positive shift without ever lifting the foot off the gas(just don't miss your shift).
Old Apr 28, 2009 | 10:25 PM
Marc V.'s Avatar
Marc V.
You should not do this because it will put more wear on the synchronizer blocking rings. The blocking rings are what slow down the gear to allow the shift collar to engage and lock the gear. Without depressing the clutch to slow the input shaft, the blocking rings will wear faster. I have 20 years experience overhauling manual transmissions, so I know a little something.
Old Apr 28, 2009 | 10:58 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Read Walt. I doubt if your lifetime warranty will pay for an abused trans. And a new trans is expensive. Not quite as expensive as having to sell the car without a trans tho. You decide.
Old Apr 28, 2009 | 11:25 PM
Rocketmanwpb's Avatar
Rocketmanwpb
As you have found you can shift if the RPMs coming down. It releases the stress on the gears and allows the shift to occur without the use of the clutch, only problem is you are wearing your syncros and eventually when the syncros wear out the car will not stay in gear. Very expensive for parts (new transmission and labor, about 10 hours out and 10 hours in.)
Old Apr 29, 2009 | 12:41 AM
Walkthedog's Avatar
Walkthedog
When some of us were wild and wooly young-ins of the 60s and 70s we used to do this all the time. I don't really know why we did. But I do not remember what we called it. Was it "speed shifting"? Maybe I did it too often and ground my memory.
Old Apr 29, 2009 | 05:37 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
It was called "speed shifting" and we did it with transmissions much less forgiving and advanced than the ones today. As to why we did it, just because we could and we thought it was cool.
Old Apr 29, 2009 | 06:09 AM
Sunset Orng 05's Avatar
Sunset Orng 05
Veteran: Marine Corps
I agree with those who say you shouldn't do it, there is reason to and all the reasons why not to. I will tell you this though, before learning it wasn't good for the tranny I managed to do it in my C5.
Old Apr 29, 2009 | 07:23 AM
evoman's Avatar
evoman
yes, it can be done in any manual trans car or truck but, why? you have a fully syncro trans so just use it the way it's supposed to be used. If all trucks were syncro, you would use your clutch all the time.
Old Apr 29, 2009 | 07:39 AM
RussellZ's Avatar
RussellZ
I usually don't clutch when I'm on my Harley except for 1st gear. It's all about timing and doesn't cause any damage to the tranny if done properly.
Old Apr 29, 2009 | 05:32 PM
Bellboy's Avatar
Bellboy
Originally Posted by deputydawg40
Nothing unusual about shifting a transmission without using the clutch. Truck drivers do it all the time including downshifting, just a matter of matching the rpms. They usually only use the clutch for initially getting the rig rolling and when stopping.......
This would be the company drivers who do not on the truck they are driving.
To Stupid Question
Old Apr 29, 2009 | 06:11 PM
GCD1962's Avatar
GCD1962
Any manual trans can be shifted this way. In fact, before sycro's were invented matching rmps was required. I once had to drive home from JFK Airport (the Idewild) to CT in a car where I couldn't disengage the clutch. Had to make every shift by feel.
Old Apr 29, 2009 | 06:13 PM
GCD1962's Avatar
GCD1962
No, it was mostly called "power shifting" Like in the Beach Boys song with the lyrics "power shift Fuelie Cool"
Old Apr 29, 2009 | 06:59 PM
JJC5's Avatar
JJC5
Wasn't "power shifting" putting in the clutch and shifting quickly without taking your foot of the gas? That gave you a kick in the *ss going into every gear.
