Accessory mode question
Apr 29, 2009 | 06:23 PM
I have an '07 A6 - if I put my car in Accessory mode, I can put the car into gear without pressing the brake. I found this to be unusual, especially since you can't do this in the ignition mode.
Is this normal?
Apr 29, 2009 | 08:10 PM
St. Jude Donor '15
"In honor of jpee"
I don't have a A6 but it does sound unusual. Seems like the car could roll then if it were accidentally put in neutral. In another car I have, in "acc" the auto trans gearshift can't be moved at all, with or without brake pedal pressure.
Apr 29, 2009 | 08:12 PM
Not Normal. I have an "06 A6
Apr 29, 2009 | 08:47 PM
Can someone verify by trying in their car?
Apr 29, 2009 | 09:33 PM
Just tried it in my '07. I too, could move the gearshift in acc. mode.
Anybody else try this ?
Apr 29, 2009 | 09:42 PM
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Quote:
Originally Posted by
gotvet
Just tried it in my '07. I too, could move the gearshift in acc. mode .
'07 Vert
Apr 29, 2009 | 10:54 PM
08 vert, must press the brake.
Apr 29, 2009 | 11:18 PM
St. Jude Donor '15
"In honor of jpee"
This is too weird; from '07 to '08 they made a change? Sounds like the must-put-in-reverse-to-shut-down for man trans in '05, subsequently changed.
Personally, I think it's a safety issue for the auto trans, but that's just my opinion.
Apr 29, 2009 | 11:51 PM
Mad*Max
My '07 allows me to move the shifter w/o using the brake while in ACC mode.
Apr 29, 2009 | 11:58 PM
Interesting. Now I have to go and check.
Apr 30, 2009 | 12:42 AM
will check on mine 09 as well
Apr 30, 2009 | 12:58 AM
I'm away from my 09 or I'd check it.
So, Just a wild guess here but has anyone tried it with the E Brake On.
And then with it Off to see if that makes a difference.
Apr 30, 2009 | 07:27 AM
gotvet
FAÇADE-C6
'07 Vert
RadarP3C
Thanks for confirming, at least I know that it is the norm for the car, but I certainly think that it could be a safety issue.
Apr 30, 2009 | 11:58 PM
I just checked my A6 09 and the shifter will Not come out of park when in accessory Mode unless I step on the Brake.
Doesn't matter if the E Brake is on or off.
