painting rear letters
1 Post
Here is the thread on painting the letters...................
http://forums.corvetteforum.com/c6-c...-corvette.html
Here are links to some more threads on the subject.
http://forums.corvetteforum.com/1559625226-post4.html
http://forums.corvetteforum.com/c6-c...lettering.html
http://forums.corvetteforum.com/c6-c...r-inserts.html
Ok I got a problem, I attempted to paint the lettering and did a good job the only thing is I got called away and when I got back to the job the paint had dried so now I new a cure on how to get the dried paint off the car. Should I wet sand and compound, Help please.
Try alcohol before wet sanding but DON'T LET IT DRY ANY LONGER!!
Lots of rubbing alcohol and elbow grease will remove it.
Use gasoline......it will remove the paint and not hurt the car, just don't let the gasoline dry on the car like you did the paint!! lol
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
I think mine were around $50..... totally worth it to me... its permanent and you dont have to worry about them anymore...... the stick on's come off sometimes... and they are more expensive in some cases....
Received 1,511 Likes
I would recommend going with the decal inserts, I think I paid close to $15 for mine and installed myself. At least if you make a mistake you can just take it off.
