alignment
Old Apr 30, 2009 | 08:02 PM
2bubbas's Avatar
2bubbas
Default alignment
took the 2008 into the dealer today-
asked for an alignment- mentioned slight cupping on edges of front tires- none on rear-
got a call telling me the tech said I needed new tires to properly align-
told them
12912 miles-
took a better look at them when I got it home- looks to me like I have 50 % of tread life left-
is the economy so depressed a tech would try to pull a fast one-
Old Apr 30, 2009 | 08:05 PM
RicK T's Avatar
RicK T
Who knows, maybe standard procedure for them. Try to find an independent alignment shop that preferably knows Vettes or at least knows how to align high end cars.
Old Apr 30, 2009 | 08:27 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
This is a fairly common problem with the front tires. I didn't notice mine at first, but when I did, I took care and ran them until they were worn too much on the inside and then bought new ones with an alignment. It seems like it might be a waste of money to align a car with such a problem but I don't know.
All four of my tires were out of alignment to different degrees. I was surprised at just how far out they were but I had them set up for longer tread life. I have a Z51 and did a couple of track days before but I don't think the new settings will affect the handling too much.
Old Apr 30, 2009 | 09:11 PM
HANNY's Avatar
HANNY
some alignment techs can be lazy or just dickh**ds. I use to work with a few. For real a really worn tire could sit uneven andcause the camber to be off for that tire but thats such an extreme case i havent seen.
Usually its from a tech who wnats to get out early or for lunch. good luck, paul
Old May 1, 2009 | 08:27 AM
BlackZ51Vett's Avatar
BlackZ51Vett
I've heard that a lot of people will come back to the alignment shop and complain that the alignment wasnt done properly because the tire still look worn even with the alignment set up properly. All the shop needs to do is to note on the repair order that the tires were worn before the alignment.
Old May 1, 2009 | 09:05 AM
magredcpe05's Avatar
magredcpe05
Default allignment
got new tires and allignment at firestone....I noted they alligned the car first with the old tires on. drives great with the new wide oval runflats..
Old May 1, 2009 | 09:23 AM
porjohn's Avatar
porjohn
I used to do alignments. You align the wheel, not the tire!
Old May 1, 2009 | 10:25 AM
Ounce's Avatar
Ounce
That's how I remember it.
oz
Old May 2, 2009 | 01:19 AM
PAmotorman's Avatar
PAmotorman
have the camber set a "0" to prevent the cupping or excess wear on the inside of the front tires.
Old May 2, 2009 | 01:33 AM
LS WON's Avatar
LS WON
Isn't this two different things? a wheel alignment and wheel balancing?
Old May 2, 2009 | 01:34 AM
LS WON's Avatar
LS WON
told them
12912 miles-
It's called the "Corvette Tax".
Old May 2, 2009 | 01:35 AM
Mike's LS3's Avatar
Mike's LS3
I just had a 4 wheel alignment done prior to installing 4 Michelin PS2's ZP tires. They attached their alignment device to all four rims and took the readings. After 16,000 miles my alignment was within factory specs, no adjustment needed. The Supercar tires wore evenly, but lacked traction when accelerating hard. The Michelin's bite nicely and ride much smoother
Old May 2, 2009 | 01:38 AM
LS WON's Avatar
LS WON
Somewhere in here is another topic about alignment and it says don't use the factory specs with the + or - settings.
I don't understand this.
http://forums.corvetteforum.com/c6-c...ering-why.html
Old May 2, 2009 | 02:33 PM
dkrhardy's Avatar
dkrhardy
Along the same lines ..... I changed from stock wheels to aftermarket wheels and new Kumho Ecsta tires, stock sizes. New wheels are front - 18x9.5 with stock offset. Rear is 19x10 with +65 offset vs stock offset which is +79. The stock wheels with stock tires wore PERFECTLY with more than 20K miles. Is there any change I should make to the alignment or should I be OK with it as is?
The whole alignment thing baffles me, but I kept the #'s that folks say get best wear. I must be close to that from the factory since I had good luck.
Old May 2, 2009 | 02:40 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Example...
C6 Camber factory setting is -0.45 +/- .60
That means -1.05 to +0.25 is totally acceptable for camber.
When you get aligned, you say make my camber -0.05 (or whatever you designate) +/- 0.0 If it's not -0.05 then he needs to adjust it again until it reads -0.05.
Does that explain the no +/- crap?
Elmer
Old May 2, 2009 | 02:42 PM
torquetube's Avatar
torquetube
What he means is that when you do an alignment, the reference plane for adjustments is the wheel surface, not the tire.
Old May 2, 2009 | 11:25 PM
LS WON's Avatar
LS WON
QUOTE=eboggs_jkvl;1569935259]Example...
Elmer[/QUOTE]
To alignment
LS WON's Avatar
LS WON
Old May 3, 2009 | 08:00 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
...is the economy so depressed a tech would try to pull a fast one-
It doesn't have as much to do with the economy as just congenitally dishonest dealership employees. That is just another reason not to go to a dealership for anything unless you absolutely have to. If you have a tire problem, go to a place that specializes in tires.
With a proper alignment the cupping will tend to go away over time. As mentioned above, you could align a car with no tires (yes, sitting on the ground on the rims) because the alignment is of the wheel and not the tire.
Old May 3, 2009 | 02:14 PM
torquetube's Avatar
torquetube
told them
12912 miles-
Are we talking about real "cupping" or just wear? Cupping is a symptom of shot dampers. I suspect we're just talking about wear.
