Launch Control?
Old May 2, 2009 | 06:25 PM
haljensen's Avatar
haljensen
Default Launch Control?
Just a re-named Traction Control with a rev limiter?
Sounds like an advertizing/sales gimmick more than a Technical advance. Magazine testers are getting better 1/4 times with Launch control OFF.
Old May 2, 2009 | 07:26 PM
Mad*Max's Avatar
Mad*Max
Old May 2, 2009 | 07:28 PM
mcwire's Avatar
mcwire
Originally Posted by Mad*Max
-- -- X2 -- --
Old May 2, 2009 | 07:49 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Hardly. Which magazine testers would these be? While I suspect that a good driver, comfortable with the launch of a high torque rear wheel drive vehicle could equal or better the results, the real benefit of the launch control is for "everyman". Think about the great equalizer of the ability of a novice to get those same times. The algorithm in use allows the less than average driver to equal the times of one of GM's best test drivers. I'd say that is pretty technically advanced.
Old May 2, 2009 | 07:57 PM
johnodrake's Avatar
johnodrake
Moderator
There was a slide that showed this and I didn't get it.
Got this though:
Old May 2, 2009 | 08:14 PM
Mark VerMurlen's Avatar
Mark VerMurlen
The computer monitors wheel spin and provides optimum power. Sort of like ABS in reverse. I'm just not sure that I'd use it other than at a drag strip. Would definitely be fun to try it a few times!
- Mark
Old May 2, 2009 | 08:16 PM
RadarP3C's Avatar
RadarP3C
I recall the GM driver had a best time of 3.60 secs for zero to sixty without launch control. With the launch control on; zero to sixty was 3.65 for every pass all day long.
EDIT: Z06 times.
Link to video with Tadge Juechter's explaining the launch control...... http://www.corvetteblogger.com/index...stem-Explained
Old May 2, 2009 | 08:25 PM
Walt White Coupe's Avatar
Walt White Coupe
I think it's a great addition to current "assists". I know it would help me.
Old May 2, 2009 | 08:34 PM
talon90's Avatar
talon90
NCM Ambassador
Got this though:
EDIT: Z06 times.
Here is the graph. The red line is the Launch control run. The blue line is the test engineer's run.
Old May 2, 2009 | 08:42 PM
LMB-C6's Avatar
LMB-C6
You can think of it as traction control but with an emphasis towards performance rather than just eliminating all wheel spin. I think the video explained the wheel spin stuff when they showed the graph. I don't think it's a gimmick, it's just another tool in the arsenal just like stability control, ABS, and the standard traction control.
To Launch Control?
