TPMS procedure
I wouldn't mind buying a set of monitors and have them installed on the AFS wheels BUT I have heard that there is a intricate procedure that must be performed for the '08's computer to accept the new monitors. And I understand that this may be required each time that I switch out the tire/wheel sets.
My question is: What is the procedure?
If this is to much of a pain in the butt I would probably just sell the tire/wheels.
Thanks for you help.
http://forums.corvetteforum.com/1565322491-post2.html
The answer to the 2nd part of your question is yes, you have to do the relearn every time you change wheels/sensors because the C6 system only stores 4 sensor ID's at a time.
- All of my TPMS sensors are bad (not likely)
- The sensors weren't registered properly at the factory (is that even possible?)
- For some reason my car doesn't have any of its original sensors (how would that happen?)
Thanks for the replies.
Check and make sure the type of wheel you have corresponds with the RPO code on the glove compartment door and your window sticker.
If not, the dealer may have swapped wheels from your car to some other car on the lot if somebody else wanted the the comp gray/chrome/polished/etc. wheels that came on your car.
If the wheels were swapped and the relearn procedure wasn't done, it's just as if you have no sensors.
Discount Tire will normally do it for free, but I agree that the dealer should be fixing a problem on a new car.
Bob
My car was not ordered. It's a 1LT car with no options and "base" wheels. It was in stock at this dealer for 7 months...so I suppose anything could have happened in that time.
The only reason I may avoid the dealer is if they want me to leave the car with them for the whole day until they can get it in. I'd rather take it somewhere that can deal with it while I wait...even if it costs a few bucks.
I will try Discount Tire. Thanks for the tip. I'll let you guys know what happens.
If you don't like that one, take a look at this one where I'm using a different tool:
I can put up a textual description if you don't understand the videos, but take a look at either one of those videos and you'll see how to put the car into the learn mode and then go around and trigger all 4 sensors to get them to send their data to the TPMS computer in the car to log the sensor ID#'s into the TPMS memory.
Bob
Alkaline C-cells never seem to last 6 months so this time I invested in rechargeable NIMH batteries so it works the first time for the first time! If you're going to make a habit of this like I have, I do recommend rechargeables.
I still don't know for sure why a brand new car with its original wheels needed to have this procedure done.
I could see some slight marring on all of my lugnuts...so there's no doubt that something happened with the wheels on my car before I purchased it (even though they are "base" wheels). Maybe they were swapped onto another car for some reason...I don't know. The current wheels all look good to me, so I'm not complaining. This car sat at the dealer for 6 months before I bought it, so I guess anything is possible.
Thanks again for the Discount Tire tip!
Take a look in your glove compartment at the sticker that has all the RPO codes for the options that your car was built with. You may see one of the following:
Wheel - 18 X 8.5 FRT & 19 X 10 RR, Aluminum, Styled
QG7
Wheel - 18 X 8.5 FRT & 19 X 10 RR, Polished
QX1
Wheel - 18 X 18.5 FRT & 19 X 10 RR, Aluminum, Painted, Flangless
QX3
Wheel - 18 X 8.5 FRT & 19 X 10 RR, Chrome, Flangless
If, for example, you see a "QX3" on the list in your car, then it had chrome wheels on it from the factory, and the dealer probably switched them from your car to one that somebody wanted to buy but it didn't have chrome wheels, and they put the base silver painted wheels on your car.
If that happened, there's one fairly big deal involved - the warranty!!!
If you have a problem with your wheels and they aren't the ones on your build sheet and associated with your VIN, they won't honor any warranty work on them.
Anyway.....there are silver painted, comp gray, polished, chrome, and gumbys available and I suspect your car had an upgraded wheel on it originally, and that the dealer swapped them off to put on another car that a buyer wanted different wheels on and your car ended up with the base wheels.
Bob
