Window issue
May 7, 2009 | 12:30 PM
Window issue
Today the driver window on my vert started doing a strange thing.
The 1/2" or so the window goes down when you open the door will now not go up when you close it. I have to hit the window switch to get it to do that.
Any ideas or quick fixes shy of taking the beast in?????
May 7, 2009 | 12:35 PM
7th Gear
Get in , put the car in accessary mode . Pull up window switch , hold for 3 seconds , repeat . should solve your problem .
May 7, 2009 | 12:36 PM
It sounds like they need to be re-indexed:
http://forums.corvetteforum.com/c6-c...lly-close.html
But more troublesome is
why they need to be re-indexed...
Try the re-indexing fix, and if the problem returns, it may be time for a trip to a dealer.
May 7, 2009 | 12:44 PM
Quote:
Originally Posted by
catcher 2
THANKS!
I disconnected the battery the other day so the car would learn to work with the new air intake. The engine light is out now.
Perhaps that did something with it.
I'll try the window trick tonight!!!!!!!!!!!!
Thanks again.
May 7, 2009 | 01:17 PM
OrangeCrush007
THANKS!
Yup - that's probably the culprit. Sounds like nothing to worry about, just needs the "reboot".
May 7, 2009 | 02:41 PM
2015 C7 of the Year Finalist
Dead battery or a disconnected battery will require BOTH windows to be re-indexed.
Elmer
May 7, 2009 | 02:58 PM
St. Jude Donor '13
eboggs_jkvl
Elmer
Maybe he only disconnected one terminal on the battery, so he only needs to re-index one window.
Sorry, I couldn't help it.
May 7, 2009 | 09:33 PM
Yippee. It worked!!!!!!!!!!!!!! Thanks, you guys are the greatest. Except the liberal ones....
May 8, 2009 | 08:33 AM
OrangeCrush007
Don't knock liberals - we're running the country (and GM). Previous crowd sure did a great job, though...
May 8, 2009 | 08:40 AM
catcher 2
May 8, 2009 | 11:43 AM
Its the first time politicians have told the truth.
Liberals said and voted for change.
Thats all I got left in my pockets now!!!!!
May 8, 2009 | 11:51 AM
coryvte
Whats this all about
May 8, 2009 | 12:15 PM
Rubber Ducky
Change one of the "n"'s to an i and you'd be spot on......
