Brake Fluid Question ?
Old May 7, 2009 | 02:25 PM
detsgt696's Avatar
detsgt696
Default Brake Fluid Question ?
I'm changing my brake calipers, powder coated. Can I use Prestone Dot 3 Synthetic brake fluid? Is it compatable with the factory fluid?
Old May 7, 2009 | 02:41 PM
RicK T's Avatar
RicK T
I'm not 100% sure but I don't think so. Read this thread, paying particular attention to the posts of our resident expert BEZ06 starting with post #5:
http://forums.corvetteforum.com/c6-c...yesterday.html
Old May 7, 2009 | 02:46 PM
nwc6's Avatar
nwc6
I would use Prestone Dot 4 fluid. It too is synthetic, has a dry boiling point of 500f and wet boiling point of 311f. It is usually stocked on the same shelf.
Old May 7, 2009 | 03:00 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Dot 3 is specified for brakes on my 06 Z51 and I use Prestone Dot 3, works fine. If you race your car you may want to use something with a higher boiling point. Dot 4 is only specified for use in the clutch master cylinder.
Old May 7, 2009 | 03:08 PM
C8-Vette's Avatar
C8-Vette
Yes
Old May 7, 2009 | 04:17 PM
detsgt696's Avatar
detsgt696
Thanks for the replies
To Brake Fluid Question ?
