I have a 2006 C6 that I bought new back in '06. It's the base model with an automatic transimission and I've been having weird issues with the transmission. For the second time now, I've started up my car and I can't get the car to shift out of second gear. The check engine light will go on when this happens. So I pull over to the side of the road, shut the car off and open and close the door to reset all of the electronics. After then waiting a few moments I restart my car and it shifts gears no problem once again, but hte check engine light stays on. Has anyone else heard of this happening? Is there something I should be aware of to prevent this from happening again?
I just looked online and Advanced Auto Parts unfortunately doesn't have any stores in California. Does anyone know of a shop similar in Los Angeles that I could get my codes read?
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
