Auto shift knob removal?
Old May 12, 2009 | 05:56 PM
speedydog5's Avatar
speedydog5
Default Auto shift **** removal?
How do I remove my shifter **** on my 2005 C6 so I can change center console
Old May 12, 2009 | 06:15 PM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
The trick is getting the boot removed. It's hard to find that 12 to 1 position.
After that, it's easy. Just take your top off stand up between the console, reach down and pull that thing as hard as you can.
Old May 12, 2009 | 06:23 PM
j_digi454's Avatar
j_digi454
I had my son pull up as hard as he could while I messed around with the collar below the **** which was turned to the 1:00 position and dropped down.
Playing with the position of the collar while my son pulled, it finally let go. There was no resistance when the **** released once the collar was in the exact position. There are detailed instruction on this Forum, if I can find them, I will post.
Old May 12, 2009 | 06:26 PM
Sherman Fretwell's Avatar
Sherman Fretwell
When I changed out the console and boots on my 07 I was in a near homicidal state until a CF member pointed out that there is a plastic tie under the chrome ring that is not shown on the GM diagram. I cut it then followed the instruction to rotate the ring to the 1 o'clock and it came right off. I've mentioned this next part before. Prior to that, my neighbors were covering their children's ears and ushering them quick step into their homes. I didn't install a new tie and haven't missed it or the neighbors kids since completing the project.
Old May 12, 2009 | 06:38 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Your profile states that you have a 2005 Corvette. If so you don't have a chrome trim ring to worry about. There is a C shaped clip that is inserted near the base of the shift **** on the side closest to the HVAC unit. You need to pry that C clip out with a small flat blade screwdriver. Once that is out you can pull the **** straight up. Once the **** is out of the way you can get the boot and console up over the shifter.
Old May 12, 2009 | 06:45 PM
Vasta's Avatar
Vasta
Good eye Paul, I never bothered to check his profile.
Old May 12, 2009 | 06:48 PM
Nikka's Avatar
Nikka
Sounds like me a few months back.......only I started to cry!
Nikka
Nikka's Avatar
Nikka
I have specific instructions IF you have a C6 - auto.
Nikka
Old May 12, 2009 | 07:04 PM
Vasta's Avatar
Vasta
Nikka
Too easy...
Old May 12, 2009 | 08:56 PM
speedydog5's Avatar
speedydog5
Nikka
if they are for a 05 that would be greatly appreciated
Old May 12, 2009 | 08:58 PM
speedydog5's Avatar
speedydog5
there is a small slit in shifter **** is that what you mean ,if so just dig out the clip???
Old May 12, 2009 | 09:01 PM
talon90's Avatar
talon90
NCM Ambassador
Yes, it is a staple clip. Just pry it out.
Old May 12, 2009 | 09:09 PM
speedydog5's Avatar
speedydog5
i,ll try that thanks
Old May 12, 2009 | 09:22 PM
Nikka's Avatar
Nikka
Default Here you go:
http://www.theredlion.us/C6%20A6%20S...20by%20WHT.pdf
Hope this helps. Mine was miserable to take off, and after it was finally off everything else was easy.
Nikka
Old Jul 25, 2009 | 04:58 PM
grayfox2424's Avatar
grayfox2424
WOW I actually got my C5 auto shifter converted to use the C6 auto shift ****...took a few days of frustration but next time ( if ever ) will be easier. I bought a complete used C6 shifter on the auction site and then purchased a used C5 auto shifter...tore the C6 one apart ( a real pain just use a dremmel and cut it up )...the C5 shifter came apart easily and then I just switched all the shifter lever parts from the C6 to the C5 shift lever....was a bear to remove the C6 **** and just as bad to replace it....THE SECRET is to rotate the boot mounting ring AND the shifter **** to the 1 oclock position,,,TURNING THE SHIFT **** TO THE 1 oclock position may NOT also turn the boot mounting ring at the same time.Lift up the boot and make certain that you turn the RING...!!!!!!!!!!!!!!!!!!!!!!!!! Then pull on the **** with ALL your strength. Finish the actual install next week but the shifter works great on the bench. ( anyone need a complete C5 auto shifter..I have an extra one now )
Old Jul 25, 2009 | 08:11 PM
budmont's Avatar
budmont
From: hamilton nj "Life's tough......It's even tougher if you're stupid."-John Wayne
I took mine off yesterday. Grab the boot just under the ****, there is a plastic housing under the fake leather. Twist it from 12 to 1 o’clock and push the housing down. Once it’s all the way down pull straight up on the ****.
Old Jul 26, 2009 | 12:37 AM
phileaglesfan's Avatar
phileaglesfan
So that was you causing all those problems in Eagle. Town is so quiet you can probably here you anywhere in the town.
To Auto shift knob removal?
Old Jun 6, 2022 | 12:36 AM
Jeffrey mantock's Avatar
Jeffrey mantock
New Member
Default Shifter ****
Nikka
I have an 06 auto that I have to replace the heater controls in the center console and I need to know how to remove the shifter **** any help would be helpful thank you
jmann106@frontier.com
Old Jun 6, 2022 | 12:46 PM
jamieo's Avatar
jamieo
It doesn't need to come off to remove the center console and radio surround.
Old Jun 6, 2022 | 02:40 PM
Gman in NC's Avatar
Gman in NC
That's exactly right. I've been in there on my '05' for a stuck in park issue and didn't have to remove the shift ****.
