2008 Front tire wear... Feather Edging
Has anybody had problems with wear on the outside out the tire. It's feather edging. I had 3800 miles on it, took it back to the dealer, and they replaced the front tires and realigned it. Now I have another 3200 miles on it since the new tires and alignment, and it's doing it again. Does GM have a problem aligning our cars? My brother bought a 2006 C6 new, and his tires prematurely wore the tires out on the insides. You would think for what we pay for these, we wouldn't have these issues. Looks like I will be on my 3rd set of front tires and third alignment with 7000 miles on the car.
Usually wearing out outside edge of your tires means that you are leaning on them hard in the corners. Do you autocross or do HPDEs with your car? That would definitely wear the outside edges. Or maybe you drive hard on tight twistly roads?
Everybody drives their cars differently, so GM can't possibly align them to one spec that is perfect for everybody. You should taylor your alignment to how you plan to use the car.
- Mark
- Mark
I really don't drive it that hard. I have my C4 to go out and hammer on. Every now and then, I will corner it a little. But overall, it really gets driven pretty easy.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
there are specs for the Corvette for easy driving (but not maximizing the handling for a road course) on this site; the search tab above will locate it. what you need to find is a very good alignment shop that has the right equipment and doesn't just align it to "within spec" but actually brings it down to what is recommended/needed. I doubt seriously that at this mileage you have an issue in your suspension components which could also cause this to happen. Suggestion: talk to racers, Corvette clubs, etc. in your area for a good alignment shop.
good luck
I am half tempted to take it a local shop that specilizes in alignments, and just pay for it. But I also think GM needs to know there are some alignment issues going on here.
St. Jude Donor '15
"In honor of jpee"
I agree with you. But please don't think this is a "set it and forget" thing. It's got to be done every once in awhile, and sometimes more often than you'd like.
It depends on your roads (potholes), what you hit (like curbs), and how you drive. Generally, it doesn't have to be done every year, or at any set mileage. The best thing is to watch your tires; they will tell you how it's going. Good luck.
I can totally relate to what you are saying. I was a ASE Certified Master Auto technician. I watch tire wear real close. Most people would glace at my front tires, and think everything is ok. I run my hand over them to check for feather edging. Alot of people don't know what that even means.
Took my 08 in to the dealer and the mechanic said that the outside wears due to the width of the tire. He went on to explain that when you are in a parking lot or some place where you make tight turns the tire slides sideways rather then rolls - I thought about it and went to a parking lot and listened when making sharp turns and I could hear and feel the tire sliding. This is on the outside edges only, I don't know about the inside wear issues.
