Screwed
Old May 13, 2009 | 03:24 PM
saibel's Avatar
saibel
Default Screwed
While cleaning the wheels. I found a very small screw embedded in the RR tire. I removed the screw and found it to be about 1/2 inch in length. The tire has been holding pressure so far. I sprayed water on the area where the screw was found and did not see any bubbles. The tire are the original Goodyear Supercar runflats.
Suggestions, is this something to just keep an eye on?
Thanks.
Old May 13, 2009 | 03:40 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
I wouldn't do anything unless it was leaking.
Old May 13, 2009 | 03:45 PM
Walt White Coupe's Avatar
Walt White Coupe
But I'd try some soapy water.
Old May 13, 2009 | 03:54 PM
AutoCutter's Avatar
AutoCutter
I think you are home free.
To Screwed
