Replacement Door Button and Ignition Button
Old May 15, 2009 | 02:19 PM
monstercb2002's Avatar
monstercb2002
Default Replacement Door Button and Ignition Button
Hey all,
I need to replace my worn out driver's door release button and my ignition button. Both buttons are pretty worn down.
Does anybody know where I can get the stock replacements and if I can install myself?
See worn down buttons pics below:
Old May 15, 2009 | 02:42 PM
danl72's Avatar
danl72
You can probably get them from Gene at gmpartshouse.com
Old May 15, 2009 | 04:58 PM
CorvettePartsBob's Avatar
CorvettePartsBob
This is Bob at Fichtner Chevrolet, a long time supporting dealer here on the Forum.
Give Tom a call at 800-234-5284 as we can get you the parts you need at less than wholesale prices and no sales tax.
firebird2002's Avatar
firebird2002
i just priced the door button i think my price was around 65.00 dollars at gm place hope that helps and it should just pop out and replace i think
Old May 15, 2009 | 05:43 PM
drich2905's Avatar
drich2905
it would also be a good time to consider a painted ingnition button from
Jimmy at Atomic Autosports or a chrome one from tkoperformance.com
Old May 15, 2009 | 05:44 PM
Gordon Shumway's Avatar
Gordon Shumway
Congratulations, wearing out the buttons that start and stop the car, and the button that lets you out must make you eligible for some kind of award around here. Maybe the anti-garage queen award.
Old May 17, 2009 | 08:03 PM
monstercb2002
Thanks for the options!
Does anybody have installation instructions? Or has replaced the buttons?
Old May 17, 2009 | 08:25 PM
DJones1220's Avatar
DJones1220
I've replaced the door button, takes about 2 minutes, take a flat blade small screwdriver nuzzle the outer silver bezel up. It will pop right off, then you'll see the button is just a plug in to the housing. Takes no time at all. Ignition button I haven't done.
Old May 17, 2009 | 10:03 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
the ignition button takes about 15 minutes to replace:
-take the torx screws out of the driver's bottom bolster.
-take bolster out.
-you should then be able to pop the bottom of the cover that houses the ignition out just enough.
-reach behind the ignition switch. The switch is held down by 4 tabs.
-pull them away from the switch gently while pushing the switch in towards the back of the trim piece.
-the switch will eventually push out from behind the cluster trim.
-Unhook the harness.
- install the harness into the replacement switch.
-Push the switch in until you hear it click in place.
-Snap the trim back in place.
-re-install the bolster piece.
go get some
Old May 17, 2009 | 10:26 PM
RPI Designs's Avatar
RPI Designs
Platinum Supporting Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16 -'17
We've got painted replacement pieces. Here are the ignition switches: http://rpidesigns.com/shop/item.asp?itemid=1454
Here are the door bezels: http://rpidesigns.com/shop/item.asp?itemid=1180
Thanks!!
__________________
RPI DESIGNS, LLC. - C5/C6/C7 Corvette Parts
4000+ C5/C6/C7 Parts & accessories - Forum members get 10% off with SS2007 coupon at checkout
Like us on www.facebook.com/rpidesigns and you might win $100.
Our brand new C7 Corvette Z06 Style Side Skirts come painted in Carbon Flash Metallic, see them here!
email: rpi.designs.customerservice@gmail.com Web: www.rpidesigns.com
Old May 18, 2009 | 02:41 PM
monstercb2002
Thanks to all who responded!!!
I'll look around for some good pricing and try the install. It seems easy enough.
Old May 20, 2009 | 08:37 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thanks for the referral. I would be happy to help anyone looking for parts.
Old Aug 8, 2009 | 01:12 PM
Erik_In_Carlsbad's Avatar
Erik_In_Carlsbad
-take bolster out.
go get some
Thanks, corvettezman! As much as I'd like to cut to the happy ending, I'm going to follow all of your directions to replace my worn out ignition button.
Old Aug 9, 2009 | 07:51 AM
monstercb2002
It's simple using his directions. I did mine in 10 minutes.
To Replacement Door Button and Ignition Button
