Reverse to drive issue?
Old May 17, 2009 | 07:01 PM
golddog's Avatar
golddog
St. Jude Donor '05 thru '24
Default Reverse to drive issue?
I back out of the driveway and into the street, when I put the car in drive there is a several second delay before I feel it kick in. Is this normal? It is an 08 auto. Thanks for the help.
Old May 17, 2009 | 07:32 PM
z06clif's Avatar
z06clif
How's the fluid level?
Clif
Old May 17, 2009 | 07:47 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Short answer is....No....especially if there is truly a "several second delay". Check trans fluid level....if low, that could be cause of problem but more critical is fact that you're losing fluid somewhere/somehow. May be time for a visit to the dealer.
Old May 17, 2009 | 08:27 PM
RicK T's Avatar
RicK T
Okay, I'm going to refer you for a little reading. It may be more than you want to read but AT LEAST read through post #27. Post 27 has a copy of a TSB on the A6 that isn't well known. Pay close attention to the 2nd heading, "Recommendation/Instructions:". Your symptom is described in the first indented paragraph:
http://forums.corvetteforum.com/c6-c...-shifting.html
Let us know what happens. Best of luck.
Old May 17, 2009 | 10:02 PM
golddog's Avatar
golddog
Thank you for that TSB post. Sounds like this may be this issue. A trip to the dealer may be necessary.
To Reverse to drive issue?
