Dual Mode Exhaust?? What the purpose?
#61
I've been looking into the M2W options and found this one with the control button on the shifter...I already purchased the toggle switch but haven't installed it yet
http://www.mamotorworks.com/corvette...1-39-9890.html
#64
The cool thing is that you cruise along sounding like the civilized touring car it is, but when you downshift and put your foot in it to pass someone it instantly acts and sounds like the 436 HP fire breathing american V-8 sports car it is. Orgasmic!
#66
No drone with bypass closed - NONE!
FYI to all you guys with NPP who hate the low rpm drone, I recently installed the insulation kit from Madvette Motorsports and there is no more drone inside with the windows up. It is louder with the M2W open but just louder - no resonance, no drone. I am guessing that the drone is from a resonance with the back of the car, cargo floor or the cubbies. This kit puts a lot of insulation on the back compartment and especially the waterfall. I added some dynamat type material to the cubbies. I cruised up and down HWY 6 in Sugar Land, TX all morning and it was a blast. For those not familiar with the area, that is a lot of lights, lots of stop and go and lots of idling! It was a major effort to put it in but it makes a remarkably significant difference.
Happy Motoring with NPP!
#67
Here is the Factory Description.
Exhaust Tail Pipe Flow Control System Description and Operation
The Exhaust Flow Control (EFC) System enhances engine performance. The system has 2 modes of operation:
• Normal
• Competition
Normal Mode
When the vehicle is stationary with the engine running the exhaust flow control module (EFCM) commands the vacuum solenoid On, which supplies engine vacuum to both exhaust flow control valves. This causes the valves to close, diverting exhaust flow through a baffled path inside the mufflers. As vehicle speed increases, throttle position reaches 25 percent or greater and engine speed reaches 3500 RPM, the EFCM commands the vacuum solenoid off. This causes the valves to open, diverting exhaust flow through an un-baffled path inside the mufflers, thus enhancing engine performance.
Competition Mode
When traction control is driver disabled, vehicle speed increases, throttle position reaches 25 percent or greater and engine speed reaches 3000 RPM, the EFCM commands the vacuum solenoid off. This causes the valves to open; diverting exhaust flow through an un-baffled path inside the mufflers more frequently and at lower engine speeds.
The system also delays exhaust valve activity during wide-open throttle acceleration to inhibit exhaust valve actuation when the accelerator pedal is released and reapplied while shifting gears.
The EFCM has the ability to detect electrical malfunctions within the system. Any electrical malfunction detected will cause the system to be disabled and increased exhaust audibility.
The system uses the engine control module (ECM), body control module (BCM), electronic brake control module (EBCM), EFCM, exhaust flow control valve vacuum solenoid, vacuum reservoir, vacuum lines, 2 exhaust flow control valves and the serial data circuit to perform the system functions.
Mine is a daily driver, and when you cruise on the hwy daily with a tie, you dont need wild sound ..................but you can take any challenge from any car at any time and that sudden ROAR really makes a difference (to hell with the Tie )
• Normal
• Competition
Normal Mode
Competition Mode
#68
The sound of the NPP opening up at 3500 RPM is phenomenal!
I have a Y intersection coming off of a freeway with a yield sign.
I always wait for a clear shot, and then let er rip, the roar of the American V8 with NPP opening up, gives me a thrill each time I do it!
