I just got new falken 452 to replace my gy runcraps . With the new tires came new valves and o rings for the tpms . The tires were filled with nitrogen and the sensors are all showing 4 lbs less pressure then the tire stores guage and my guage show.
Does anyone have any ideas what is causing this ?
ps. these falkens are a drastic improvement over the GYs
Your location shows FL. If you were at 5-6,000 feet altitude the TPMS would show 4 pounds less than actual pressure.
Ummmmm..... That makes no sense..... True at elevation the ambient environmental pressure is less but that will not change the interior pressure. Tires are a closed system that are for all intents and purposes non-elastic. temperature will change pressure but not elevation. Sensors are probably out of calibration.... They "should" read exactly what a Tire pressure meter does at the valve stem. I have 1 out of 4 sensors like that. dont know how to fix it but doesnt really bother me since i know the TPS baseline...
thanks guys...I live in Florida which is 10 feet msl ( above sea level ). I have driven the car for a while at highway speeds . I am still at aloss for the tire pressure disparity . They are all exactly 4 lbs off with 3 different high quality tire gauges.
Gauges measure the pressure in the tire ABOVE ambient pressure. The sensors are totally within the tire and can't read ambient. They compare pressure within the tire to a programmed value, sea level air pressure. The higher the altitude the more the TPMS reads low.
The tires are brand new and have not changed from showing 32psi on the tire stores gauge and both my digital and analog gauges ; while the car sensor shows 28 . The pressure has remained steady .
Did they install new sensors?
If you deflate one tire by two pounds, drive around the block a few times to wake up the system, does the reading in the DIC update to reflect the lower pressure?
they installed a kit with new o rings and valves and put the old sensors back on . If I lower the pressure and drive around, the new pressure will show up ; only it will be 4psi lower then the gauges show.
This is true. The sensors would work like a tire gauge if they DID have access to ambient pressure...but they don't.....so they read low as elevation increases. I live at 6000 and they read low here, but accurate when I am in Ca. at the beach. Glad I didn't have this car when I lived at 10,150'
Somehow I knew this member was from about a mile high before I looked at his profile (Albuquerque, NM). My consistently read 10% (IE 3psi low compared to two manual gages (Digital and old school) that I have. It doesn't matter what temperature the tires are at, although temperature drops/increases will affect your tire pressure. Best to check them cold every morning while you are driving especially out west where 5-10k feet is nothing.
I have no idea about the OP's problem though. Maybe the nitrogen is screwing up the sensor's ready since it is not regular air. I considered nitrogen just because it is more stable but if it screws up the sensor readings forget it.
Ya, my house is at 5,970' MSL. Don't have a clue to help the OP. That's a wierd one.
The ironic thing is that they worked right before the tire change
Just for grins, dump the nitrogen, refill with air. Check your readings. Years ago I worked at an airport, on some of the aircraft we used nitrogen for tire fill. Pressure would remain more stable at different altitudes and temps.
The difference you see is the difference in the accuracy of measurement between the TPMS and a non-digital, or digital handheld guage. There will always be some disparity in the readings. In atlanta I always see about a 1-3psi difference in my measurements vs. the tpms. Especially if the temperature changes a lot during the day.
