Need some help...
Old May 25, 2009 | 10:34 PM
SC Vette06's Avatar
SC Vette06
Default Need some help...
My Emergency Brake light won't come on when i engage the parking brake. Any suggestions? as far as i know its working. (i put it in neutral on a hill)
Old May 25, 2009 | 10:37 PM
danl72's Avatar
danl72
Maybe he bulb burned out in the dash.
Old May 26, 2009 | 06:29 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It could be the parking brake lamp switch. The switch is located at the base of the parking brake assembly (down in between the seat and the center tunnel.) You would need to remove the entire parking brake assembly to gain access to the switch. Start by removing the handle and the boot and try to see if the switch connection has become damaged, loosened or if a wire was pinched.
To Need some help...
