Safe to drill ??
Old May 31, 2009 | 10:36 AM
Dogosaur's Avatar
Dogosaur
Default Safe to drill ??
Can anyone tell me if it is safe to drill into the small hump that separates the passenger compartment from the trunk area ??...(sorry I don't know any other way to explain it)
Old May 31, 2009 | 10:40 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You'll need to be more specific. That area (directly behind each seat) houses the gas tanks. There are also a couple of hoses that run between the two tanks. Picture an arrangement that likes a saddle bag with the tank on either side behind the seat and the hoses between them.
Can't say completely that it is safe to drill because I don't know where you plan to drill nor how big of a drill you plan to use. You can do some damage if the drill is long or in the wrong location.
Walt White Coupe's Avatar
Walt White Coupe
Not very deep because that's where the gas tanks are.
Old May 31, 2009 | 10:44 AM
Dogosaur's Avatar
Dogosaur
I haven't drilled...but someone has. The holes appear to be fairly small, maybe a 32d of an inch...like someone use a small sheet metal screw or something. What comes to mind is a drink holder installation or something like that. I was planning on putting some type of manual mount there and was checking out the area and found 3 small holes...then found corresponding holes in the carpet back. Made me curious.
Old May 31, 2009 | 10:49 AM
Dogosaur's Avatar
Dogosaur
The holes are centered in the area between the drivers seat and passenger seat. I am planning on sealing them up...need to make sure nothing behind was damaged but I have no idea if anything is in that area.
Old May 31, 2009 | 10:51 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
You're going to have to give us more details on the size and location of the holes before any recomendations can be made.
What are the holes going to be used for? There may be a different way to accomplish what you're trying to do.
Old May 31, 2009 | 10:54 AM
cthusker's Avatar
cthusker
Be very helpful if you posted a picture of exactly where the holes are....
Old May 31, 2009 | 11:23 AM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
Sounds like somebody had a camra mount mounted there. I was thining of doing the same thing.
Old May 31, 2009 | 11:42 AM
Dogosaur's Avatar
Dogosaur
I was going to install one of those caddys that holds cups and a few knick knacks. I think I'll figure out something that doesn't require any drilling. Right now the car is in the shop otherwise I'd have posted some pic's. Hopefully I'll get it back next week sometime and may post some then.
My thoughts are that if any fuel or other lines were penetrated I would have an odor of some type.
From the depressions in the carpet, it appears that two rectangular objects about 6" apart measuring 1" x 3" were there. The only thing I could think of were those old cup holders. Dealers take everything out of a car so I just can't say for sure...???
Old May 31, 2009 | 11:43 AM
VET4LES's Avatar
VET4LES
These tanks are behind the seats.
Old May 31, 2009 | 11:55 AM
Dogosaur's Avatar
Dogosaur
Now THAT is an educational photo. I think I am OK. THANK YOU guys !! This is one hell of a good forum and it's folks like you that make it that way.
Old May 31, 2009 | 12:08 PM
dietrich@ou.edu's Avatar
dietrich@ou.edu
Default Tanks
Are those tanks pictured upside down ? How does the gas transfer from one to the other ?
Old May 31, 2009 | 12:11 PM
Maui's Avatar
Maui
St. Jude Donor '08
What the heck are those? Are they on the verts only?
Old May 31, 2009 | 12:32 PM
Fonzijr1964's Avatar
Fonzijr1964
same for both
Old May 31, 2009 | 12:47 PM
shopdog's Avatar
shopdog
They are right side up. The tank on the left of the picture is the driver's side tank and the tank to the right is the passenger side tank. That bright corrugated hose connecting them is the path for fuel transfer. Inside that pipe is a small pipe that connects between a fuel pickup in the passenger tank and a venturi pump in the driver tank. That's what transfers fuel from the passenger tank to the driver's tank. The latter also houses the primary fuel pump which draws fuel for the engine from a well in the driver's side tank. When the tanks are filling, after the driver side tank nearly fills, fuel starts to spill over to the passenger tank via the corrugated hose. That continues until both tanks are full.
Old May 31, 2009 | 12:51 PM
dietrich@ou.edu
I agree this is a cool forum !!!
Old May 31, 2009 | 12:52 PM
Fonzijr1964
yeah and it is almost never fast enough to get the auto fill pump to keep filling
To Safe to drill ??
Old May 31, 2009 | 01:06 PM
cclive's Avatar
cclive
We want a pic of these holes...
Old May 31, 2009 | 10:27 PM
Dogosaur's Avatar
Dogosaur
I will do that...I promise. But I have to get the car back from the shop. The tranny blew on it last Friday so the dealership I bought it from is putting a new one in (no rebuilds). Hopefully I will get it back this week and I will take photos of exactly what I'm talking about.
Old May 31, 2009 | 10:45 PM
TEXHAWK0's Avatar
TEXHAWK0
If the holes are drilled the damage has already been done. I read a post where someone found screws in this area and they were fine until they removed the screws. The screw had actually gone into the gas tank, but did not lead as long as the screw was in the hole.
