Replacing Ignition Switch Procedure?
Old Jun 2, 2009 | 12:16 AM
niceguy753's Avatar
niceguy753
Default Replacing Ignition Switch Procedure?
Just purchased a DSOM Painted Ignition switch module. The last time I worked on the dash was when I switched out the 2 dash pieces for the GM DSOM Painted ones....but that was 4 years ago and I don't remember removing this lower section. Any Help? Please....
Old Jun 2, 2009 | 12:40 AM
nwc6's Avatar
nwc6
You will have to pull the gauge bezel off. Not hard, and held in by those metal clips that fit into the plastic slots. Here is a thread with picures. You won't have to removed the switch pods to get to the ignition switch. I would lower the steering wheel as low as it goes, and extend it too. I also put a towel over the top of the steering wheel and behind it to protect it from the metal clips:
http://forums.corvetteforum.com/c6-c...many-pics.html
Old Jun 2, 2009 | 12:42 AM
RAT's Avatar
RAT
Thanks, doing the very same thing.
To Replacing Ignition Switch Procedure?
